ND filters with step-up ring on wide angle lens
texasphoto
p.1 #1 · p.1 #1 · ND filters with step-up ring on wide angle lens
I am considering to buy a 82mm circular ND filter and a 77-82 step-up ring to use on Canon 16-35mm F4L lens. Would the step-up ring cause vignetting? Also would vignetting be an issue if I stack up two circular ND filters on this lens? Thank you for sharing your experience.
Jul 25, 2017 at 09:59 PM
sjms
p.1 #2 · p.1 #2 · ND filters with step-up ring on wide angle lens
I've been doing that for a long time now. None of the rings I use cause any vignetting from 72 to 82. Al fiters are 82
Jul 25, 2017 at 11:07 PM
texasphoto
p.1 #3 · p.1 #3 · ND filters with step-up ring on wide angle lens
Do you see vignetting at 16mm?
Jul 26, 2017 at 02:09 AM
sjms
p.1 #4 · p.1 #4 · ND filters with step-up ring on wide angle lens
at 16mm FF and 11mm DX using the 82mm (direct) on the 11-20/2.8 Tokina and 17-35/2.8 FF Nikon 77mm using 77-82 step ring nothing at all regularly. I have used it on the 16-35/4G too with no Vignette. now I do use the Breakthrough Photography ND filters and rings which are shallow to begin with.
Jul 26, 2017 at 02:22 AM
texasphoto
p.1 #5 · p.1 #5 · ND filters with step-up ring on wide angle lens
what is the thickness of the breakthrough step-up ring? I was thinking about getting it. I saw Sensei 77-82mm is 3mm.
Jul 26, 2017 at 02:56 AM
texasphoto
p.1 #6 · p.1 #6 · ND filters with step-up ring on wide angle lens
Have you tried stacking 2 Breakthrough ND filters on these lenses?
Jul 26, 2017 at 02:59 AM
sjms
p.1 #7 · p.1 #7 · ND filters with step-up ring on wide angle lens
I don't stack. i haven't found a need to.
I would say though that as you extend out things will start to show up.
Jul 26, 2017 at 04:30 AM
Norm Shapiro
p.1 #8 · p.1 #8 · ND filters with step-up ring on wide angle lens
Although not as wide as some of the other lenses mentioned here, I've stacked my old Nikon 52mm 8X nd under a Breakthrough 52-77mm adapter with their 6X no on my 20mm f/3.5 on my D700 and no problems.
Jul 26, 2017 at 05:56 AM
