Peak Design Everyday Sling bag as a lens changer bag for ...
Dj R
p.1 #1 · p.1 #1 · Peak Design Everyday Sling bag as a lens changer bag for wedding/portrait shooters
QUICK review of how I'm packed for next Friday, my next wedding.
I will arrive with a gear bag and a lens changer bag. The gear bag will contain three bodies, all attached to lenses, and a few other items. But the gear bag will be left behind (mostly empty) and not used much if at all.
My assistant will have a FF body and 24-70, not changing much, if at all. She will carry this lens changer bag. At times I will switch to a lens that is in this bag. And at times we will replace a battery or two, in my bodies. I dual wield. Typically 28/58, 28/70-200, 58/70-200.
Wedding & Portrait shooters could consider this bag as an option for a lens changer bag. Because it works as a LC Bag, however, it doubles as a sling bag for everyday use, and travel.
PEAK DESIGN EVERYDAY SLING BAG
and packed a little differently:
Edited on Jul 31, 2017 at 08:58 PM · View previous versions
Jul 23, 2017 at 07:17 PM
sjms
p.1 #2 · p.1 #2 · Peak Design Everyday Sling bag as a lens changer bag for wedding/portrait shooters
I have seen it used effectively as a diaper bag too
Jul 24, 2017 at 03:36 AM
Norm Shapiro
p.1 #3 · p.1 #3 · Peak Design Everyday Sling bag as a lens changer bag for wedding/portrait shooters
So where do you keep your back up bodies and lenses? You mentioned your larger transport case is pretty much empty once you are set to work.
Jul 24, 2017 at 05:04 AM
Paul Mo
p.1 #4 · p.1 #4 · Peak Design Everyday Sling bag as a lens changer bag for wedding/portrait shooters
I have a Tamrac messenger that I can configure similarly - discreet black and a lot cheaper. But I am sure this PD option is better ergonomically.
Jul 24, 2017 at 09:11 AM
Dj R
p.1 #5 · p.1 #5 · Peak Design Everyday Sling bag as a lens changer bag for wedding/portrait shooters
I shoot with two FF on me, with a money maker strap.
D810
D750
My assistant has my other D750 and 24-70E on her
that is three there
I use 20mm 1.8, 28mm 1.4E, 58mm 1.4, 70-200 2.8E VR
plus my second shooter has three bodies, all FF. with six lenses.
cheers
Edited on Jul 25, 2017 at 02:00 AM · View previous versions
Jul 24, 2017 at 05:14 PM
Norm Shapiro
p.1 #6 · p.1 #6 · Peak Design Everyday Sling bag as a lens changer bag for wedding/portrait shooters
When I'm on the job (TV productions doing stills). I have backups for almost everything. I shoot woth two bodies and have two backups. And I have backups on almost all my lenses, especially for the ones I use the most. Many years ago when I did weddings with a Hasselbald I had back up for everything including my Norman 200B lights.
Jul 24, 2017 at 06:59 PM
Dj R
p.1 #7 · p.1 #7 · Peak Design Everyday Sling bag as a lens changer bag for wedding/portrait shooters
that is great
do you feel that I need more backups on me?
I am there with 6 bodies and 12 lenses.
Jul 24, 2017 at 07:17 PM
Norm Shapiro
p.1 #8 · p.1 #8 · Peak Design Everyday Sling bag as a lens changer bag for wedding/portrait shooters
Well at least backup your main lenses and have at least one spare body. Equipment going down is no excuse not to complete the job.
Jul 24, 2017 at 09:17 PM
Dj R
p.1 #9 · p.1 #9 · Peak Design Everyday Sling bag as a lens changer bag for wedding/portrait shooters
@michael h
Jul 24, 2017 at 09:25 PM
eke2k6
p.1 #10 · p.1 #10 · Peak Design Everyday Sling bag as a lens changer bag for wedding/portrait shooters
I'm continuously surprised by the number of photographers who don't know about this incredible gadget. I dual wield too with monemakers, and can carry an extra lens or two with this bad boy, all without having to bring another bag.
Jul 25, 2017 at 02:56 PM
sjms
p.1 #11 · p.1 #11 · Peak Design Everyday Sling bag as a lens changer bag for wedding/portrait shooters
there was a Korean gent that showed a version off a year earlier at Photo Plus in NYC. not really into that concept. a few variables that could be problematic in use. lots of useful things out there some less so. once you're over the wow factor it gets old.
Jul 25, 2017 at 03:55 PM
Dj R
p.1 #12 · p.1 #12 · Peak Design Everyday Sling bag as a lens changer bag for wedding/portrait shooters
I love the innovation in this. I own a lot of their gear, but that one aspect of their lineup is not for me.
Jul 25, 2017 at 06:12 PM
eke2k6
p.1 #13 · p.1 #13 · Peak Design Everyday Sling bag as a lens changer bag for wedding/portrait shooters
I've used it for 20+ weddings, and it's going stronger than ever. You can change a lens with one hand, by simply removing it, putting it on the empty mount, and flipping around to the new one. Takes a couple of seconds, and you're back shooting.
I tried it after fumbling with bag orientation when using the moneymaker. It's worth a try!
Jul 25, 2017 at 06:18 PM
Dj R
p.1 #14 · p.1 #14 · Peak Design Everyday Sling bag as a lens changer bag for wedding/portrait shooters
1 issue
money maker is tough to stuff in here if you have two bodies, each with a prime on there.
Aug 11, 2017 at 02:12 AM
