Dehaze LR6
mysh
p.1 #1 · p.1 #1 · Dehaze LR6
I was wondering if lightroom Dehaze feature works for light leak into a night sky. I am still using LR5 so I don't have this feature.
Would it work for the hazy look that happens sometimes in night shots from lights?
Jul 17, 2017 at 07:14 PM
rdeloe
p.1 #2 · p.1 #2 · Dehaze LR6
I was going to suggest that you try to recreate it in LR 5 because I know you can do that in LR 6 stand-alone... but I think you're out of luck. The question came up in an earlier thread here, and the answer seems to be that you can implement a work-around in LR 6 standalone because the code that does it in CC is buried in there, but it's not in LR 5 at all. https://www.dpreview.com/forums/thread/3976402
So this isn't an answer to your question, but possibly useful if you were hoping to make it work in LR 5 with a workaround!
Jul 17, 2017 at 07:40 PM
mysh
p.1 #3 · p.1 #3 · Dehaze LR6
Thanks for this info. I will definitely look into this.
Jul 17, 2017 at 08:04 PM
photoin.nyc
p.1 #4 · p.1 #4 · Dehaze LR6
You could install the trial version and test it yourself. Each situation is different so you could get a better understanding how much you can or cannot fix.
Aug 02, 2017 at 09:49 PM
Ian.Dobinson
p.1 #5 · p.1 #5 · Dehaze LR6
I have no idea if it will do what you want . you could try the trial and see of ask someone who has it to try for you .
but be aware that the dehire slider is ONLY a feature in LR CC not LR6 Standalone . personally its one of the features thats worth the cost of entry .
you can of course get work arounds for the slider in standalone LR6 . never tried any as I have CC
Aug 03, 2017 at 09:29 AM
dhphoto
p.1 #6 · p.1 #6 · Dehaze LR6
The workround for LR6 standalone dehaze is effective elegant and free:
https://www.proloststore.com/free/
I assume the dehaze presets are only a carefully crafted set of LR controls anyway so it should be possible to achieve a similar effect and save is as a series of presets in LR5
LR6 is a much better program though
Aug 03, 2017 at 09:56 AM
mysh
p.1 #7 · p.1 #7 · Dehaze LR6
Why do you say its much better? From what I have read people say there isn't a lot of improvement besides Dehaze. I read that the library and catalog was improved but actual editing is almost the same outside of the dehaze feature.
What else besides dehaze and catalog is worth upgrading for?
Aug 05, 2017 at 11:19 PM
dhphoto
p.1 #8 · p.1 #8 · Dehaze LR6
All sorts of editing like gradients, the ability to use different colour temperature on parts of the image, keystone controls, all manner of things that I wouldn't be without now
LR6 is worth the upgrade
Aug 06, 2017 at 07:06 AM
