CanadaMark Offline Upload & Sell: Off
Google Wifi works well if you are set on a mesh system. Most major brands offer extenders as well.
How big is your house though? Myself and several colleagues use the Netgear R7000 Nighthawk and it will cover 3000+ sq ft of living space across all 3 floors and max out a 180 Mbps connection anywhere you test it, and only a slight drop in speed on the deck and garage. You may just need a better router, and could likely get away with a single unit - the Apple routers are nothing special. Mine's in the basement, and I get max speeds on the upstairs 3rd floor, and my brother is using one in his upstairs bedroom, and it can max out that same connection in his basement in a much larger house.
