k-h.a.w Offline Upload & Sell: Off
MedicineMan404 wrote:
K-H
You might have an interest.
My cat Milo at ISO 25,600.
What can you say about this image?
http://www.stopitdown.com/2017/06/22/sony-a9-iso-25600/
Thanks Robert. Actually an interesting exercise.
You seem to have gone the JPG route.
On page 2 of the first menu did you have high ISO noise reduction on?
Also where do the vertical and horizontal stripes in the OOF background area come from?
So, I would approach this differently.
I would start with shooting raw, lossy compressed, or even better uncompressed.
Then high ISO noise reduction in camera is ignored. Good that's what you want. I would keep that setting on Off.
When taking the raw image I would try to get the cat properly exposed.
In post you don't want to pull shadows up. That only increases noise.
Pulling highlights down in post is not a problem. That doesn't increase noise.
Getting the cat exposed correctly at ISO 25,600 is the way to go.
There will be quite a bit of noise at the pixel level.
No problem, we'll get rid of that later.
So I would use the latest version of Capture One Pro 10.
Keep sharpening and noise reduction at their default settings. We take care of that with Nik.
On page 3 of the C1P10 tools you can play with AWB. Ignore that for right now.
There are 3 color wheels below the WB.
The right most one has a slider for changing the high intensity light level.
If necessary pull that down, then go to page 4 for typical adjustments, also on page 5.
Then I send a tif file, 16bit, RGB to CS6. (I shoot RGB, not sRGB.)
First thing I do is use Define 2 of Nik, to smooth the noise in the OOF background area.
The noise in the cat is probably fine, don't make it more visible by smearing it.
I know if I shot with my A9 and 90/2.8 MACRO G OSS the infocus areas would be incredibly sharp.
So skip sharpening for now.
Back to CS6. Combine the layers, maybe try Auto Contrast.
Switch to 8 bit from 16 bit, and switch from RGB to sRGB.
Save the finished JPG image.
I am by no means an expert in any of this.
But this is how I get by.
K-H.
