       2       3              9       10       end
Sony releases new Firmware Updates!
Admin
p.1 #1 · p.1 #1 · Sony releases new Firmware Updates!
Sony released new firmware updates for many of their E-mount cameras. Some are long waited fixes like the option for wider apertures during focusing acquisition with certain lenses and hopefully the Star Eating issue has been resolved.
Download it below:
  1. A9
  2. A7rII
  3. A7sII
  4. A7II
  5. A6500
  6. A6300
Sony A9:
Change specifications for overheating warning
_____________
Sony A7rII and A7sII:
Adds “Auto Pwr OFF Temp.” function(*)
(*)If the same part of your skin touches the camera for a long period of time while using the camera, even if the camera does not feel hot to you, it may cause symptoms of a low-temperature burn such as redness or blistering.
Pay special attention in the following situations and use a tripod, etc.
When using the camera in a hightemperature environment
When someone with poor circulation or impaired skin sensation uses the camera
When using the camera with the [Auto Pwr OFF Temp.] set to [High]
Improves operability of the camera:
Improves operability when AF area is set to flexible spot
Refer to here for details.
Adds “Live View Display” into custom button assignation
Adds “Set File Name” function
Supports visible light LED in external flash for AF (HVL-F45RM)
Improves release time lag when wireless flash is used
Optimizes exposure algorithm during focusing when [Live View Display] is [Setting Effect OFF]
Improves image quality when Long Exposure NR setting is OFF
Improves overall stability of the camera
_____________
Sony A7II:
_____________
Sony A6500:
Supports new lens “SEL100400GM”
Optimaizes image stabilization performance in movie mode
_____________
Sony A6300:
Modifies aspect of guide frame display in LCD (2.35:1 mode)
Jun 08, 2017 at 03:24 PM
scalanc2
p.1 #2 · p.1 #2 · Sony releases new Firmware Updates!
There is version 4. for A7RII.
Jun 08, 2017 at 08:10 AM
normie610
p.1 #3 · p.1 #3 · Sony releases new Firmware Updates!
Yes, a user reported that the updates corrects the focusing behaviour, at least on the 85 GM it's now focusing wide open instead of at shooting aperture when settings effect is OFF.
Great news indeed!
Jun 08, 2017 at 08:49 AM
scalanc2
p.1 #4 · p.1 #4 · Sony releases new Firmware Updates!
Not wide open but 2.0.
On 24-70 4.0 and 70-200 4.0 closes at 5.6 (setting effect OFF).
With setting effect ON it closes at the shooting aperture.
Jun 08, 2017 at 09:17 AM
Lotus Eater
p.1 #5 · p.1 #5 · Sony releases new Firmware Updates!
Why would it stop down slightly when focusing? To reduce focus shift?
Jun 08, 2017 at 09:34 AM
normie610
p.1 #6 · p.1 #6 · Sony releases new Firmware Updates!
Thanks for the correction. F 2.0 should be more than sufficient.
Jun 08, 2017 at 09:37 AM
scalanc2
p.1 #7 · p.1 #7 · Sony releases new Firmware Updates!
Yes, I think this is done to correct focus shift on some lenses.
If one stop is not enough one can always turn setting effects on.
Jun 08, 2017 at 09:43 AM
GMPhotography
p.1 #8 · p.1 #8 · Sony releases new Firmware Updates!
This is a big update we wanted if this does more wide open focusing.
Jun 08, 2017 at 10:13 AM
GMPhotography
p.1 #9 · p.1 #9 · Sony releases new Firmware Updates!
Flash lag time improvement and a lot more. Someone has been listening. We've been screaming about some of these folks. Good to see Sony giving us these updates. I'll load up soon here.
Keep reporting any findings you see.
Jun 08, 2017 at 10:21 AM
nampramos
p.1 #10 · p.1 #10 · Sony releases new Firmware Updates!
They added a new function to the custom button, so that's possible. Would have been nice to have the Crop Mode/APS-C mode added in there as well. It is a real pain going in to the menus for that every time...
Jun 08, 2017 at 10:25 AM
GMPhotography
p.1 #11 · p.1 #11 · Sony releases new Firmware Updates!
Agree I would love the APS custom button.
updating my A9 now
Jun 08, 2017 at 10:34 AM
Stoffer
p.1 #12 · p.1 #12 · Sony releases new Firmware Updates!
Yes! The bad news for you Guy is that you now have to buy the 85 GM again!
Jun 08, 2017 at 10:35 AM
GMPhotography
p.1 #13 · p.1 #13 · Sony releases new Firmware Updates!
i know it already crossed my mine. Actually I have a great Sony 85 and if i can get the damn sigma 135 updated better I would be happy
Jun 08, 2017 at 10:46 AM
GMPhotography
p.1 #14 · p.1 #14 · Sony releases new Firmware Updates!
Okay FYI updated the A9 and A7rII and all is good. Need to try it in action but went smooth
Jun 08, 2017 at 11:18 AM
LBJ2
p.1 #15 · p.1 #15 · Sony releases new Firmware Updates!
Wow! Big update. Taking some time to go through the process too ( for the a7rII). Some reading material why I wait:
"Changes in the operations for moving the focus area position"
http://support.d-imaging.sony.co.jp/www/support/ilc/products/ilce7m2/update/en.html?id=spt_dl_ilce7rm2
Jun 08, 2017 at 11:21 AM
DavidBM
p.1 #16 · p.1 #16 · Sony releases new Firmware Updates!
Improvement in image quality for long long exposures with noise reduction turned off?
Does this mean
(a) no star eater algorithm (i.e. less processing)
or
(b) additional filtering
I'm hoping it's (a)!
Jun 08, 2017 at 11:36 AM
bjornthun
p.1 #17 · p.1 #17 · Sony releases new Firmware Updates!
That's great, it gives the new A6500 style AF point selection.
Jun 08, 2017 at 11:42 AM
bjornthun
p.1 #18 · p.1 #18 · Sony releases new Firmware Updates!
The update is out also for A7II, A7SII, A6300 and the A6500.
Jun 08, 2017 at 11:43 AM
Stoffer
p.1 #19 · p.1 #19 · Sony releases new Firmware Updates!
I can confirm this for the 85 GM.
Jun 08, 2017 at 12:31 PM
Stoffer
p.1 #20 · p.1 #20 · Sony releases new Firmware Updates!
Wow, finally! *breaks down in tears of joy and relief*
Jun 08, 2017 at 12:41 PM
       2       3              9       10       end
       2       3              9       10       end
