Help with Cyber Commander and CSR+ ?
oguruma
p.1 #1 · p.1 #1 · Help with Cyber Commander and CSR+ ?
Issue: I cannot change the power of an ABR 800 using a CSR+ and Cyber Commander.
I just got a used CSR+ from a forum member. I am trying to use it with a Cyber Commander on an ABR800.
I currently have an Einstein E640. The CC and the E640 works as it should.
Problem: The CC can fire the ABR800, but I am unable to adjust the flash output with the CSR+ connected.
CSR+ is connected to the ABR800 via the RJ-11 cord and (of course) 120V AC Power.
I can fire the ABR800 with both the camera shutter and the light meter function of the CC.
When I remove the CSR+ and connect the camera to the ABR800 via PC Sync cable, I can control the flash power.
Any ideas? This is my first time using this setup, so I am assuming I am doing something wrong. The manual only tells me to set the frequency and the channel, which I have done.
Jun 04, 2017 at 01:10 AM
kaplah
p.1 #2 · p.1 #2 · Help with Cyber Commander and CSR+ ?
oguruma wrote:
Any ideas?
http://www.paulcbuff-techforum.com/viewforum.php?f=8 is your best bet.
Jun 05, 2017 at 02:35 PM
RDKirk
p.1 #3 · p.1 #3 · Help with Cyber Commander and CSR+ ?
Are you saying that you can control the flash power via the CC when connected to the camera via the PC cable? I find that surprising.
Have you tried replacing the RJ-11 cord? Be sure to use a 4-line replacement, but you can find short RJ-11 cables at most stores with phone equipment, such as a big-box home store, Best Buy, or even Walmart.
Jun 20, 2017 at 11:57 PM
calk
p.1 #4 · p.1 #4 · Help with Cyber Commander and CSR+ ?
It is my understanding that in the Alien Bee series, the flash power can only be controlled via the sliders on the back panel of each light.
Cal
Jun 21, 2017 at 06:13 PM
RDKirk
p.1 #5 · p.1 #5 · Help with Cyber Commander and CSR+ ?
Cal
The Alien Bees can be power-controlled by the CyberCommander if the connection is proper and everything is working correctly. I have five of them working just peachy with the CC.
Jun 22, 2017 at 03:19 AM
calk
p.1 #6 · p.1 #6 · Help with Cyber Commander and CSR+ ?
I stand corrected and thank you. I will research the PCB website.
Cal
Jun 22, 2017 at 11:32 AM
