Which are your most/least used lenses?
nandadevieast
p.1 #1 · p.1 #1 · Which are your most/least used lenses?
Not the best, the most/least used.
Thanks.
May 20, 2017 at 05:43 PM
mitesh
p.1 #2 · p.1 #2 · Which are your most/least used lenses?
Most used: 300 IS PRO
Least used: 75/1.8
May 20, 2017 at 05:57 PM
James Farrell
p.1 #3 · p.1 #3 · Which are your most/least used lenses?
Probably a meaningless response given I have only owned my 2 EM1.2 bodies and 4 OLy m43 lenses for about 4 months. But in the time that I've owned them and on the outings that I've been on ... most used is by far the Oly 40-150/2.8 Pro by a wide margin. Least used would be my Oly 7-14 since I've not done any Landscape trips yet (but will do so very soon). For what I like to shoot, the Oly 40-150/2.8 Pro is simply an awesome piece of hardware. It is the best lens I have ever owned by any manufacturer. I will be on some extended trips later this year during which my Oly 300/4 IS Pro will get extensive use. I don't own any primes.
May 20, 2017 at 07:24 PM
bobbytan
p.1 #4 · p.1 #4 · Which are your most/least used lenses?
Favorite lens: 42.5 Nocticron.
Most used: 12-40 PRO ... I think.
Least used: 60 Macro.
May 20, 2017 at 11:37 PM
Julius
p.1 #5 · p.1 #5 · Which are your most/least used lenses?
Most used: 12-100 F4
Least used: 60 Macro F2.8
May 21, 2017 at 04:06 AM
nandadevieast
p.1 #6 · p.1 #6 · Which are your most/least used lenses?
Bobby sometimes I think about this lens. Nocticron. But as per plan, portraiture is a responsibility of Sony FF, and I don't want to load myself with too many lenses. How often do you use it?
This lens is 85/2.4 and they are charging a bomb. But pictures are really nice, no doubt.
May 21, 2017 at 07:26 AM
nandadevieast
p.1 #7 · p.1 #7 · Which are your most/least used lenses?
Btw, there is an artist from Pakistan who does a great job with Nocticron.
May 21, 2017 at 07:29 AM
Fred Amico
p.1 #8 · p.1 #8 · Which are your most/least used lenses?
Don't use my m43 gear that much, but when I do, it's usually the 12-40 Pro on my E-M1.
May 21, 2017 at 05:50 PM
Katy C
p.1 #9 · p.1 #9 · Which are your most/least used lenses?
Most used Pana 12-35mm f2.8 & Leica 100-400mm.
Least used Olympus 75mm f1.8.
May 21, 2017 at 09:42 PM
bobbytan
p.1 #10 · p.1 #10 · Which are your most/least used lenses?
I use it quite a lot actually, as 85mm FL is quite versatile i.e. not just for portraits. You can use it for street photography, landscape work, etc. Having said that, I shot some portraits with my 75/1.8 last Saturday as I needed I needed a little more reach than the Nocticron. Will post some images in the next couple of days.
Edited on May 21, 2017 at 11:59 PM · View previous versions
May 21, 2017 at 11:57 PM
bobbytan
p.1 #11 · p.1 #11 · Which are your most/least used lenses?
Do you have a link to his gallery/website?
May 21, 2017 at 11:58 PM
pr4photos
p.1 #12 · p.1 #12 · Which are your most/least used lenses?
most used is 12-35mm, and least used is 30mm
May 22, 2017 at 01:39 PM
jimworth
p.1 #13 · p.1 #13 · Which are your most/least used lenses?
Most used is Oly 12-40 f/2.8. Least used is 15mm.
May 23, 2017 at 03:27 PM
AmbientMike
p.1 #14 · p.1 #14 · Which are your most/least used lenses?
It just varies. I picked up a lens I bought in the 90's and haven't really used much, and started using it a couple days ago. Last year I used a 300/2.8 a lot, now it's sitting around again.
I use 70-210 or so glad zooms quite a bit, I suppose, and a 24mm OM sees fairly regular use over the past months. But it varies
May 26, 2017 at 04:27 AM
