Archive 2017 · Canon Err01 with adapter to nikkor lens
kenji
p.1 #1 · p.1 #1 · Canon Err01 with adapter to nikkor lens
i have this ebay nikkon lens adapter for canon body, with contacts pts work fine with my 5dii
but, it gives me err 01 with my 5dsr, i found 2 solutions on the net, and
1 )rotate the lens back a little from the mounted position.
2) file the adapter 3mm at the 10'oclock position from other forum (with 1dn not sure about 5dsr)
https://www.photo.net/discuss/threads/1d2n-err-01-with-old-film-lens.475414/
what is the other solution?
or i have to look for other adapter if there is any.
thanks for your input.
Edited on May 15, 2017 at 10:05 AM · View previous versions
May 15, 2017 at 09:34 AM
kenji
p.1 #2 · p.1 #2 · Canon Err01 with adapter to nikkor lens
Err 01 by iamkenji, on Flickr
May 15, 2017 at 09:39 AM
Jess_Sullivan
p.1 #3 · p.1 #3 · Canon Err01 with adapter to nikkor lens
Hmmm- why do you need contacts? I was a big fan of nikkors with my 5d- I seem to recall my adapter is simply bayonet to bayonet with no chips or anything. Just enable "shoot w/o lens" and you are good to go.
If you want focus confirm from your chip, remember eyeballing it still works better in most cases.
-Jess
May 15, 2017 at 10:30 AM
p.1 #4 · p.1 #4 · Canon Err01 with adapter to nikkor lens
You should try the rare and fabled mylar anulus, for Alt lenses.
https://www.fredmiranda.com/forum/topic/1459935/0#13800283
It works for me.
May 15, 2017 at 11:40 AM
kenji
p.1 #5 · p.1 #5 · Canon Err01 with adapter to nikkor lens
i tried the tape method. it works. i don't need the af point, it just came with it from ebay
May 15, 2017 at 12:00 PM
jhg photo
p.1 #6 · p.1 #6 · Canon Err01 with adapter to nikkor lens
It may be a general limitation of these chipped adapters.
I have one for CY> EOS that worked fine with my 5D II but had issues with a 5D III. It turned out that it only locked the camera with slightly longer exposure, about 1/15 s and slower, in combination with continous shooting. Single shots were ok. Try if it works at higher shutter speeds and if not in burst mode.
Good luck
May 22, 2017 at 06:35 AM
