Alan321 Offline Upload & Sell: Off
p.1 #2 · p.1 #2 · Help with Windows PIA unwanted file copy produced | |
Could it be that you have accidentally dragged the selection a little bit by moving the mouse a little and dropping it, effectively at the same location ? Perhaps your mouse button is not giving you adequate tactile feedback.
If you ever recognise that something like that is happening, keep the mouse button pressed but also press the ESC key.
While the display is showing files in list format, only a short drag is required to copy the files, but if you use thumbnail mode then a bigger drag would be needed to give the same effect and that makes it less likely to be done accidentally.
