Telephoto question about Oly vs Pan Leica
Herbc
p.1 #1 · p.1 #1 · Telephoto question about Oly vs Pan Leica
My main landscape work is done with Sony, but I have a new Pen F Oly that is my walkabout
friend.
I am interested in a good tele, preferably 300mm or more, that has the best bird sharpness results. I have read a lot about the Oly 300 vs the Pan Leica, but I suspect there are more candidates available- Price is not a huge consideration, but what I have seen so far only the Oly 300 fits this niche.
Ideas are appreciated.
Apr 01, 2017 at 04:27 PM
garyvot
p.1 #2 · p.1 #2 · Telephoto question about Oly vs Pan Leica
Herbc wrote:
I am interested in a good tele, preferably 300mm or more, that has the best bird sharpness results. I have read a lot about the Oly 300 vs the Pan Leica, but I suspect there are more candidates available...
In native micro four-thirds? I could be wrong, but i don't really think there are many alternatives to the Oly, outside of a slower zoom. You can use adapted lenses, or an Oly 300 2.8 four-thirds DSLR lens (if you can find one), but they will have greater or lesser autofocus limitations depending on the body and adapter combination you use.
At a 600mm-equivalent FOV, this focal length is still rather niche for the format, unfortunately.
Apr 01, 2017 at 07:46 PM
galenapass
p.1 #3 · p.1 #3 · Telephoto question about Oly vs Pan Leica
Other candidates:
four-thirds:
Zuiko 50-200mm f/2.8-3.5 Digital ED SWD
300mm f/2.8
All require an adapter and are probably slower focusing than the lenses you mention.
Canon lenses:
100-400L
400L
etc...
Would require an adapter, again with slower focus. The 400mm focuses reasonably fast with a metabones adapter.
There are other consumer zoom lenses xx-300mm in m43 format, but the optical qualit is not that great.
Right now the Oly m43 300mm f/4 and Pan Leica 100-400 are the best options in native format.
Apr 01, 2017 at 08:07 PM
Herbc
p.1 #4 · p.1 #4 · Telephoto question about Oly vs Pan Leica
Thanks, that seems to be it- Leica had a nice tele that was in this range, I will have to hunt one up. I am leaning toward the 300, but the 100-400 is lighter and has some appeal, although from what I read it is not as good as the 300 in image quality.
Apr 01, 2017 at 08:11 PM
bobbytan
p.1 #5 · p.1 #5 · Telephoto question about Oly vs Pan Leica
There isn't another m43 or 43 lens with a higher resolution or sharpness than the Oly 300/4 PRO. Olympus have said that this is the sharpest lens they have ever produced.
Apr 02, 2017 at 04:51 AM
bobbytan
p.1 #6 · p.1 #6 · Telephoto question about Oly vs Pan Leica
Herbc
p.1 #7 · p.1 #7 · Telephoto question about Oly vs Pan Leica
looks like the 300 is it.
thanks for the replies.
Apr 02, 2017 at 04:29 PM
BruceO
p.1 #8 · p.1 #8 · Telephoto question about Oly vs Pan Leica
I believe that the Pen F supports dual IS (sync IS) with the Oly 300 but not with the Panasonic lenses.
Apr 24, 2017 at 03:39 AM
rxgolf
p.1 #9 · p.1 #9 · Telephoto question about Oly vs Pan Leica
Might want to see what output is good enough for your work?
Greg
  E-M1MarkII    LEICA DG 100-400/F4.0-6.3 lens    400mm    f/7.1    1/800s    1000 ISO    0.0 EV
  E-M1MarkII    LEICA DG 100-400/F4.0-6.3 lens    400mm    f/9.0    1/1000s    800 ISO    0.0 EV
  E-M1MarkII    LEICA DG 100-400/F4.0-6.3 lens    400mm    f/8.0    1/800s    400 ISO    0.0 EV
  E-M1MarkII    LEICA DG 100-400/F4.0-6.3 lens    400mm    f/10.0    1/320s    200 ISO    0.0 EV
  E-M1MarkII    LEICA DG 100-400/F4.0-6.3 lens    350mm    f/8.0    1/500s    400 ISO    0.0 EV
Apr 24, 2017 at 03:56 AM
Herbc
p.1 #10 · p.1 #10 · Telephoto question about Oly vs Pan Leica
Thanks a ton Greg- I was leaning toward the PL after considering the lack of a zoom. I tried out the Canon G3X and sent it back, but your work is all anybody could ask for. I will order the pl. Thanks again.
Apr 24, 2017 at 02:14 PM
elkhornsun
p.1 #11 · p.1 #11 · Telephoto question about Oly vs Pan Leica
The Olympus optical stabilization provided with its E-M5 and E-M1 cameras works in tandem with that in the Olympus 300mm f/4 lens. I get sharp pictures shooting hand held with this combination at shutter speeds as slow as 1/8s. It is truly remarkable. I might add the 100-400mm but would not go with this instead of the 300mm lens as I would lose in the optical stabilization and in speed with the slower zoom lens.
The Olympus 300mm f/4 and the 40-150mm f/2.8 zoom lens will also work with the Olympus 1.4 teleconverter.
Apr 24, 2017 at 10:39 PM
Herbc
p.1 #12 · p.1 #12 · Telephoto question about Oly vs Pan Leica
getting more confused- I have a Pen F, which I presume has the same IBIS that the other have? So the oly 300 would work with the Pen F as well??
Apr 25, 2017 at 04:47 PM
JPTrunck
p.1 #13 · p.1 #13 · Telephoto question about Oly vs Pan Leica
The Pen-F comes with sync-IS as part of its IBIS, so it should work with the 300mm/f4 and produce about 6 stops of IS. Per the info from the B&H site about the Pen-F:
"For increased stabilization when working with longer lenses that incorporate lens-shift type image stabilization, 5-axis sync IS is also supported, this combines the effectiveness of the sensor-shift image stabilization along with the lens-specific optical image stabilization. This helps to compensate for up to six stops of camera shake for more effective handheld shooting with telephoto focal lengths and slower shutter speeds."
Jim
Apr 25, 2017 at 07:54 PM
