Profoto B2 Battery Issue?
cambyses
p.1 #1 · p.1 #1 · Profoto B2 Battery Issue?
I had bought an extra B2 battery used (in 9+ condition) from B&H late last December. When I received it, I did a quick test and I thought it was functional, so I just put it in my bag as my backup battery. I never got to use it again until yesterday. But then it seemed fully discharged. So I put it on its charger, and even after many hours of charging, only two of the 4 status indicator LED's would turn on, and once I put the battery on the pack, and connect a light, the pack would turn on for a second and then turn back off without firing even a single shot. I then removed battery from the pack, and pressing on the test button, noticed that even those 2 status LED's would not turn on anymore.
So the battery is obviously defective. But I am just curious, has anyone seen anything like this with your B2 (or even B1) batteries?! This is the only one of my 5 Profoto batteries (3 B1's, and 2 B2's) that seems defective.
I called B&H, and thankfully they accepted to take it back and issue me store credit (kudos to them as I am just a couple of days past the 90-day warranty they offer on their used gear, but then again this was just a backup battery and never got to be used until yesterday).
Mar 27, 2017 at 04:53 PM
stevesanacore
p.1 #2 · p.1 #2 · Profoto B2 Battery Issue?
If they're willing to take it back, I would jump on that and just purchase a new one. It usually doesn't pay to purchase used batteries unless you know they are like new, (very few cycles).
Mar 27, 2017 at 05:08 PM
stuuke
p.1 #3 · p.1 #3 · Profoto B2 Battery Issue?
I had two B1 batteries die. One under warranty the next one died 1 month out of warranty. Profoto offered me a slight discount but not nearly enough in my opinion for 100% failure rate in a kit.
Mar 28, 2017 at 02:19 AM
zurkzees
p.1 #4 · p.1 #4 · Profoto B2 Battery Issue?
Anyone looked into re-celling the B2 battery?
I use the setup heavily and profoto seems to
want users to buy new battery instead of offering
re-celling like the older products.
Mar 28, 2017 at 02:27 AM
Conner999
p.1 #5 · p.1 #5 · Profoto B2 Battery Issue?
I've seen that before - and B&H offered a full refund / credit immediately. Looked good at 1st glance but when started use it dropped dead in a hurry.
Mar 28, 2017 at 11:55 AM
cambyses
p.1 #6 · p.1 #6 · Profoto B2 Battery Issue?
Thanks guys... Yes, B&H offered me store credit, which I intend to use for a new replacement battery. I had it shipped back today. So will see how quickly they process it and issue the credit.
I am surprised to hear about these battery issues with Profoto... I know battery technology still needs to catch up with the advances in the broader electronics industry, and battery failures are rather common. But for the amount of money Profoto charges for these batteries, one would hope that they be more reliable. Oh, well, with the GN7 battery fiasco, I guess we should still be happy that at least these batteries fail safely
Mar 28, 2017 at 09:48 PM
bgateb760
p.1 #7 · p.1 #7 · Profoto B2 Battery Issue?
I've owned my B2's for about 2 years now, and the battery performance has been degrading severely on one of my batteries; It barely holds any charge, but I suspect it's because I always left it trickle charging when shooting small product stuff indoors, and having a battery constantly connected to a charger doesn't seem to be good for it.
My second battery seems okay, though.
Apr 14, 2017 at 08:29 PM
MayaTlab
p.1 #8 · p.1 #8 · Profoto B2 Battery Issue?
Interesting to know. Have you talked to a technician about that ?
Apr 15, 2017 at 07:19 AM
rico
p.1 #9 · p.1 #9 · Profoto B2 Battery Issue?
Lithium secondary cells are not trickle charged, and the charger won't perform such a function. Given that short working life, I suspect a bad battery.
Apr 15, 2017 at 03:01 PM
pjny
p.1 #10 · p.1 #10 · Profoto B2 Battery Issue?
I had the same issue with B2 battery. Very annoying. Just died. I use the B2 now with AC adaptor charging the unit and it works.
I dont use the B2 as much as the B1s so I'm a little peeve to have the B2 battery last less than 2 years. I use the B1 constantly and the battery is rock solid. They are also about the same price but the b1 battery has way more capacity. B2 is 21.6 Wh.
I am not buying anymore Profoto lights because I expected better quality for the price. The plastic model button on the B2 fell off and at close inspection I see it is not very well designed and can easily tear off. I dont use the B2 as much as the B1 and the premature death of the battery is disappointing in terms of quality control of expensive batteries.
My friend, who has a lot of profoto gear, got afew Flashpoint xplor 600 and loves the system especially since you can power it via ac or battery.
May 07, 2017 at 05:44 PM
