PetKal Offline Upload & Sell: Off
p.1 #8 · p.1 #8 · Anyone still renting Original Canon 300 2.8 IS? | |
omarlyn wrote:
Curious: Why are you interested in renting the V1 version? It's a great lens (i should know, I own one) but if the question is regarding renting, why would you be interested in renting the V1 version rather than the current version?
I suppose the V1 rental would provide a bit more relevant operating evaluation (test) , if one is interested in buying a copy of the V1 lens, and not the V2.
However, if one has a good handle on how long (or short) 300mm FL is, and also how heavy (or light) the lens is to shoot with, then the rest of 300 f/2.8 IS MkI or MkII features are extremely unlikely to disappoint anybody.
In my own experience, I jumped from 300 f/4 IS to 300 f/2.8 non-IS without renting anything beforehand. Obviously I knew what to expect reach-wise, however, I underestimated the 300 f/2.8 non-IS weight effects. In those days, shooting with the 3 kg lens handheld was quite burdensome as I lacked practice of that type. After some time, I upgraded to 300 f/2.8 IS MkI, again, with no prior renting, and I was delighted with the IS lens.
Similarly, I went to 300 f/2.8 IS MkII without feeling the need for any prior rentals, and that is perhaps one of my highest valued lenses ever.
Therefore, assuming the OP has got a good feel for 300mm FL, the only reason I would suggest renting 300 f/2.8 IS MkI before buying it, is to make sure that the lens weight doesn't pose too much of a hindrance for the intended manner of lens use. The rest of the lens traits, i.e., the build and performance, is as good as it gets.
Edited on Mar 30, 2017 at 05:38 PM · View previous versions
