BSPhotog Offline Upload & Sell: On
It depends what you're shooting. If you're doing portraits then you certainly need a softbox or umbrella or some kind of diffusion. If you're running and gunning just shooting candid around the room, then you want a medium-wide lens and bouncing off the ceiling or walls will be good.
If it were me, I'd probably go with the 24-105. Set your exposure for the ambient that you want behind your subjects. f/4, 1/160, ISO 800 would probably be a good start. Set the flash to TTL and bounce it off the ceiling and you'll probably be good.
You can run into problems shooting subjects who are a long distance from you when bouncing flash of the ceiling right above you. Inverse square law.
