LR issue with 'blank' export
omarlyn
p.1 #1 · p.1 #1 · LR issue with 'blank' export
Whenever I export images from LR6, I regularly get random 'blank' images. By "blank images", I mean that all the files appear to export properly and a thumbnail will appear for each file... but randomly, some of those files will just be a white image. It doesn't seem to matter if I'm exporting 10, or 1,000 images... it seems that somewhere around 1% of the exported images come out blank. Interestingly, I usually export with a watermark and the watermark is always visible even when the image is 'blank'. If I go back to LR and re-export only those images that were blank, they will export properly. Anyone seen this before?
Omar
Feb 26, 2017 at 12:40 AM
omarlyn
p.1 #2 · p.1 #2 · LR issue with 'blank' export
Anyone?
Mar 20, 2017 at 10:55 PM
dhphoto
p.1 #3 · p.1 #3 · LR issue with 'blank' export
I use LR6 extensively and haven't seen this. Have you tried not using a watermark? This may be the culprit.
Mar 21, 2017 at 07:56 AM
omarlyn
p.1 #4 · p.1 #4 · LR issue with 'blank' export
Hmmm... as obvious as that may seem, I have not tried that. I will try a sample export with and without watermarks and compare.
Omar
Mar 21, 2017 at 05:22 PM
