Lightroom Problem
Jeff Winters
p.1 #1 · p.1 #1 · Lightroom Problem
Lightroom is seeing my library, but when I go to import it doesn't see it. Very confusing.
Feb 24, 2017 at 10:35 PM
Jeff Donald
p.1 #2 · p.1 #2 · Lightroom Problem
Why would you import from your library? Images are generally imported from a tethered camera or internal or external card reader. Images may be "Added" to the catalog from hard drives. Adding leaves the images on the drive and indexes them in the library.
The destination for importing/copying should be where the images on the camera or card will be stored such as an internal or external HD.
Feb 25, 2017 at 12:57 PM
gschlact
p.1 #3 · p.1 #3 · Lightroom Problem
Jeff W.
For Lightroom to "see" a folder that you placed external of Lightroom into the library folder structure, it needs to have a media file in it otherwise Lightroom won't include it. However, if you create the folder in Lightroom and then dump your photos into it, you can then Eith import or I find easier a Synchronize of that folder to get the contents into the library.
Mar 14, 2017 at 06:51 PM
