       2       3              9       10       end
Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Develo...
Geoff CB
p.1 #1 · p.1 #1 · Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Development
http://photorumors.com/2017/02/22/cosina-announced-the-development-of-three-new-full-frame-voigtlander-lenses-for-sony-e-mount/
I want that 40mm 1.2 badly. I love the 40mm f2 adapted to my A7r II, hopefully it has the same great rendering.
Feb 23, 2017 at 01:53 AM
Admin
p.1 #2 · p.1 #2 · Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Development
Images:
Voigtlander APO-MACRO LANTHAR 65mm f/2 Aspherical E-mount
Voigtlander NOKTON 40mm f/1.2 Aspherical lens for E-mount
Voigtlander Classic NOKTON 35mm f/1.4 lens for E-mount
Feb 23, 2017 at 02:09 AM
banpreso
p.1 #3 · p.1 #3 · Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Development
I'm interested to know the weight and bokeh of the 40 1.2. The link says 10 blade aperture and MFD of 40cm. I wonder if it will also come out on M mount which can offer close focus and AF capability on Sony with adapter. The link specifically said the 40mm would be compact.
Edited on Feb 23, 2017 at 03:48 AM · View previous versions
Feb 23, 2017 at 02:12 AM
ken.vs.ryu
p.1 #4 · p.1 #4 · Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Development
Please make them m mount too.
Feb 23, 2017 at 02:24 AM
bjornthun
p.1 #5 · p.1 #5 · Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Development
Photorumors posted a link to this press release, in Japanese. Google translate does an ok-ish job with it.
Feb 23, 2017 at 02:52 AM
Admin
p.1 #6 · p.1 #6 · Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Development
Here is the ok-ish translation.
https://translate.google.com/translate?sl=auto&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fwww.cosina.co.jp%2Fcp2017%2Fcp-2017-pless.pdf&edit-text=&act=url
Feb 23, 2017 at 02:55 AM
bjornthun
p.1 #7 · p.1 #7 · Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Development
I wonder, if Cosina will make an E mount version of the Voigtländer 21/1.8 VM later?
The 65/2 apo and the 40/1.2 asph look very interesting.
I don't think the 40/1.2 is that big, and I suppose that an AF 40/1.2 would be quite a bit larger.
Feb 23, 2017 at 02:56 AM
ISO1600
p.1 #8 · p.1 #8 · Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Development
Dammit just when I thought I couldn't get pulled back to an A7. I want this 35 is the min focus is something reasonable.
Feb 23, 2017 at 03:01 AM
bjornthun
p.1 #9 · p.1 #9 · Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Development
I didn't know, I could insert a pdf file in google translate, thanks!
It looks like the 40/1.2 asph is intended to be well corrected, and the 35/1.4 will be a character lens.
GMPhotography
p.1 #10 · p.1 #10 · Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Development
Wow this is fun stuff.
Feb 23, 2017 at 03:06 AM
MikeEvangelist
p.1 #11 · p.1 #11 · Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Development
Awesome!
Feb 23, 2017 at 03:11 AM
rji2goleez
p.1 #12 · p.1 #12 · Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Development
Damn, this is fun. Can someone please wipe the drool from my face . . .
Feb 23, 2017 at 03:17 AM
DavidBM
p.1 #13 · p.1 #13 · Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Development
Yes mine too. When can i preorder the 40mm?
I doubt it will come in M mount. Difficult to make a fast lens that will work well on both sensor stacks. The slow wides were so slow they could get away with it.
Feb 23, 2017 at 03:44 AM
Admin
p.1 #14 · p.1 #14 · Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Development
^ Indeed!
Feb 23, 2017 at 03:47 AM
Admin
p.1 #15 · p.1 #15 · Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Development
How sharp should we expect the 40/1.2 to be wide open?
LightShow
p.1 #16 · p.1 #16 · Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Development
The 65/2 APO Macro will go nicely with my Leica R 100 APO Macro and 180/3.4 APO if it can beat my R 60 Macro... then a rereleased 125 APO Macro!
The 40/1.2 is interesting, much smaller than the 35/1.2, if the 40/1.2 is as good, it will be great fun!
On the other hand I do wish it was APO too, f2 would have been acceptable as well.
Feb 23, 2017 at 03:50 AM
Mathieu18
p.1 #17 · p.1 #17 · Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Development
That 35/1.4 would be great for me, but looks like it's probably based on the current Nokton which is meh...
Feb 23, 2017 at 04:03 AM
Admin
p.1 #18 · p.1 #18 · Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Development
yes, the 35/1.4 will have some RSA.
This is from the English translation:
"Suitable for the name of classic, by intentionally letting the aberration remain moderately, in open, gentle"
Feb 23, 2017 at 04:07 AM
DavidBM
p.1 #19 · p.1 #19 · Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Development
I would have guessed not very. But they do seem to be making claims for its wide aperture homogeneity. As long as its good in fairly big central area and great across the field by f 4....
Edited on Feb 23, 2017 at 04:15 AM · View previous versions
Feb 23, 2017 at 04:14 AM
Mathieu18
p.1 #20 · p.1 #20 · Voigtlander E-mount 35mm 1.4, 40mm 1.2, 65mm f2 in Development
Yea, just a hunch (but a good one) that the 35 is an adapted 35/1.4, since it's not highly corrected wide open didn't change a ton. The 40/1.2 is probably an adapted 35/1.2 that got a bit longer when corrected for the Sony sensor stack. That would indeed be a pretty exciting lens.
Have you ever shot the 35/1.2? It's fun... Very useable wide open too.
       2       3              9       10       end
       2       3              9       10       end
