12-100 vs 12-40 + 40-150 ?
nandadevieast
p.1 #1 · p.1 #1 · 12-100 vs 12-40 + 40-150 ?
Hi
I was just wondering which of these could be a better combination. Earlier the 12-100 wasn't there so it was straightforward.
The pair is a stop faster obviously, heavier, lesser IS capability than the 12-100 and obviously its not a 1 lens solution.
Olympus 300/4 gets paired with the zoom combo very well. 12-40/40-150/300 wnd TC
But 12-100 leaves a gap from 200mm to 600mm so Panasonic 100-400 is a better pair with this lens.
Any thoughts?
Feb 18, 2017 at 04:18 PM
RobCD
p.1 #2 · p.1 #2 · 12-100 vs 12-40 + 40-150 ?
nandadevieast wrote:
Hi
Any thoughts?
Well, I think it depends greatly on how you intend to use the lenses. The great thing about the 12-100 is that you aren't giving up image quality in the way that you usually are when choosing a superzoom type lens so it really comes down to the extra stop and the extra range of the 40-150 compared to the one lens option with better IS. What I like about the 12-100 is the ability to have the extra reach with you at all times without having to carry the 40-150 and without having to change lenses. For me the 12-100 is a landscape lens and general travel lens. I have a couple of primes for low light so I don't really need the 12-100 to fill that role. For those that want to use zooms for low light I can see how the extra stop would be a benefit although for me I still find f2.8 too slow and prefer the primes. The 12-100 may or may not fit your needs but I can tell you that it is a really impressive lens. It is probably the best lens buying decision I have made in a long time.
Feb 18, 2017 at 04:46 PM
mitesh
p.1 #3 · p.1 #3 · 12-100 vs 12-40 + 40-150 ?
12-100 plus PL 100-400 is a super combo. I don't think you can find a better two-lens solution to capably cover such a huge focal length range. Combined with E-M1.2, that's a nature and wildlife shooter's dream setup.
Looking at my gear list, you'd never know it, but I do believe in "less is more". Unless you really want/need the f/2.8 zooms or the 300 PRO, why go for a three lens solution when two lenses may very well cover your needs (and do it at less expense)?
Feb 18, 2017 at 05:31 PM
flash
p.1 #4 · p.1 #4 · 12-100 vs 12-40 + 40-150 ?
The 12-100 plus 100-400 will probably become my default travel kit base. Maybe even woth the 7-14 which makes a high quality 14-800 kit in three lenses. add a 25mm 1.8 and you're golden.
Or I'll just take the 12-100 and a Pen F and be done with it....
It's a brilliant time to be in m43. The possible lens combinations we can put together are almosr endless. Some will prefer a 12-40 and 40-150 solution and orhers the 100-400 and 12-100. There's not going to be a right or wrong solution, just lots of cool choices.
Gordon
Feb 18, 2017 at 09:37 PM
bobbytan
p.1 #5 · p.1 #5 · 12-100 vs 12-40 + 40-150 ?
And life will get a lot more complicated with the release of these 3 new pro-grade Panasonic-Leica lenses, which in all likelihood will be at least as good as all the previous Panasonic-Leica lenses. We are so spoilt with so many great options, but it's all good!
http://www.43rumors.com/the-three-new-panasonic-leica-zoom-lenses-coming-in-2017-which-one-do-you-like/
Feb 18, 2017 at 10:46 PM
Julius
p.1 #6 · p.1 #6 · 12-100 vs 12-40 + 40-150 ?
Gordon
You are right, so not to have any dilemma I have all 5 of them to pick the combination I want.
I had the 12-40 since the E-M1`came out then paired with the 40-150 was excellent combo, but when the Leica 100-400 became available I knew I just had to have it, then the 12-100 appeared and I just could not resist.
However in most situations most likely I will just walk around with my E-M1 MK II with the 12-100mm on it unless I expect some wildlife and/or wide angle situation.
This 12-100mm is a fabulous lens.
Feb 19, 2017 at 12:02 AM
millsart
p.1 #7 · p.1 #7 · 12-100 vs 12-40 + 40-150 ?
I think you have to ask yourself how import it is to every have focal length covered. For me its not really all that important.
For example, I often carry my 28mm Leica Q for wider shots, and then the GX8 with a 75/1.8 on it, for compressed landscapes, portraits etc.
huge, really, really YUGE, gap between those two focal lengths but 95% of the time it works just fine for me, and how I like to compose.
I could weight down the bag with a 25mm, 45mm, etc to fill in some gaps, but having done exactly that in years past all that happens is those lens stay in the bag and see next to zero use.
Feb 19, 2017 at 01:54 AM
flash
p.1 #8 · p.1 #8 · 12-100 vs 12-40 + 40-150 ?
yep. iwill have them all soon as well. haven't picked up my 12-100 yet.
Gordon
Feb 19, 2017 at 04:42 AM
nandadevieast
p.1 #9 · p.1 #9 · 12-100 vs 12-40 + 40-150 ?
12-100 has been reviewed by lenstip, at 12mm its close to highest resolution they got from any M43 lens ever.
Feb 19, 2017 at 05:30 AM
bobbytan
p.1 #10 · p.1 #10 · 12-100 vs 12-40 + 40-150 ?
At 12mm it's up there in terms of resolution - but it's not better than the Olympus 75/1.8 or PL Nocticron - and it's just average at the 100mm end.
Feb 19, 2017 at 07:28 AM
TMaG82
p.1 #11 · p.1 #11 · 12-100 vs 12-40 + 40-150 ?
For me it's more about size/comfort than most, especially since now with modern technology most of these recent releases will be close enough to each other. The added 2.8 versus 4 speed isn't that big of a deal for me either since the added length of the 12-100 can give more compression at longer lengths at f/4 than the 12-40 can at 40 a 2.8. Also for depth of field purposes there's not that much difference between a f/5.6 and F/8 equivalent to be honest. Also the 2.8 would normally come in handy shooting event indoors but for me while a 24-70 f/2.8 on say a D810 or another capable FF camera is useable at ISO 5000+, on a m4/3 I try to avoid it, and using a 2.8 zoom indoors in less than perfect lighting you'll be at ISO 4000+ a lot. For indoors I switch over to a 1.2/1.4/1.8.
But a reason why I would get the 12-40/40-150 is the added reach and the lighter size if needed. The 12-40 is a good walk around lens for me, the 12-100 I'd feel it be too big/heavy even on a E-M1 II.
Feb 19, 2017 at 10:31 AM
nandadevieast
p.1 #12 · p.1 #12 · 12-100 vs 12-40 + 40-150 ?
550 grams
40-150 = 880 grams
Feb 19, 2017 at 12:46 PM
bobbytan
p.1 #13 · p.1 #13 · 12-100 vs 12-40 + 40-150 ?
12-40 = 382 grams
550 grams
40-150 = 880 grams
Feb 19, 2017 at 01:27 PM
bobbytan
p.1 #14 · p.1 #14 · 12-100 vs 12-40 + 40-150 ?
Panasonic 12-35 = 305 grams = $700.
bobbytan wrote:
12-40 = 382 grams
Feb 19, 2017 at 01:30 PM
millsart
p.1 #15 · p.1 #15 · 12-100 vs 12-40 + 40-150 ?
Don't forget about the Pan/Leica 12-60 f2.8/4 variable aperture zoom, which weights just 320 grams as well......
Feb 19, 2017 at 06:14 PM
bobbytan
p.1 #16 · p.1 #16 · 12-100 vs 12-40 + 40-150 ?
That sounds very attractive actually. Hopefully it renders as beautifully as the other Panasonic-Leica lenses. If so I will happily replace my Oly 12-40 for the PL 12-60.
Feb 19, 2017 at 06:26 PM
Julius
p.1 #17 · p.1 #17 · 12-100 vs 12-40 + 40-150 ?
The 12-100 maybe rated average at 100mm, but when I made comparison shots at 100mm f/4 between the 40-150 and the 12-100 the 12-100 appears to be a bit sharper with more micro details than the 40-150, although both are excellent.
Feb 19, 2017 at 06:48 PM
RobCD
p.1 #18 · p.1 #18 · 12-100 vs 12-40 + 40-150 ?
It looks to be just slightly behind the Panasonic 35-100 in the center at 100mm and equal to the 35-100 on the edges. Compared to the Olympus 40-150 f2.8 it looks to be slightly behind in the center and the edges and it looks to be better than the Panasonic 100-400, I don't know if there are any good comparisons for other lenses like the 14-150, 40-150, 14-140 type lenses but I'd be surprised if the 12-100 isn't better or worst case equal to those at 100mm. So I'm thinking the 12-100 is likely to be better than all but the very best two zooms available and very close to both of those, especially the 35-100.
I know average is kind of a loose term but I find it hard to place the 12-100 in the average category even at 100mm but again I realize average is a loose term and I can see how it might apply relative to the rest of the range since 100mm is the weakest focal length although the differences aren't very much. I think maybe the 100mm focal length gets more criticism than it deserves because the rest of the range is that good.
Feb 19, 2017 at 07:30 PM
bobbytan
p.1 #19 · p.1 #19 · 12-100 vs 12-40 + 40-150 ?
Good point. Let me clarify or define what I mean by average. Average in terms of pro-grade m43 lenses like the other PRO series lenses, Oly 75/1.8, the Nocticron and other PL lenses. It would be above average when compared to the less expensive consumer-grade lenses.
Feb 19, 2017 at 08:09 PM
millsart
p.1 #20 · p.1 #20 · 12-100 vs 12-40 + 40-150 ?
Having owned both the 35-100/2.8 and 40-150/2.8, and finding them both very good with their own sets of pros and cons, I will say that both of them don't come close to the overall optical quality of the 75/1.8.
Of course they offer a more versatile range, but the images from the 75/1.8 have significantly finer detail, better across the frame sharpness, better contrast, and even when the 75/1.8 is stopped down to f2.8, better overall rendering. With the 75mm wide open at f1.8 its still sharper than either lens at f2.8, and has a far smoother OOF rendering.
I actually sold the zooms because the 75/1.8 gave such stellar IQ, and was such a compact little lens that I far preferred carrying it.
Depending on ones photographic needs though, there certainly is a good case to own either zooms.
I would say they are both in the very good category, with glass like the 75/1.8, 42.5/1.2 and 300/4 falling into the truly excellent quality range, not just for m4/3, but for any mount.
Feb 19, 2017 at 08:56 PM
