kdphotography Offline Upload & Sell: Off
Don't forget---you can also plug in the B2 pack charger and charge and shoot at the same time. Can't do that with the B1. It's a good idea to have a second battery to swap in should you deplete the first battery.
The VML should work as a power source to recharge the B1 and B2 batteries---might be handy for those times when an a/c outlet is not available and you need to charge one battery while the other is in use. I just purchased the new Omnicharger a battery pack that has both USB and a/c plugs; it is substantially smaller and lighter than the VML. The Omnicharger works great with the Profoto B1/B2 charger.
ken
