Archive 2017 · SB800 TTL stopped working
Tony Admana
p.1 #1 · p.1 #1 · SB800 TTL stopped working
My SB800 TTL has stopped working and only works on RPT and M modes. Has anyone with Nikon speedlight SB800 had a similar experience? Any advice will be greatly appreciated.
Jan 13, 2017 at 11:09 AM
rico
p.1 #2 · p.1 #2 · SB800 TTL stopped working
Dumb ideas: clean contacts on flash and hot shoe; ensure proper seating; ensure no pins are bent on the flash.
Jan 13, 2017 at 11:41 AM
Tony Admana
p.1 #3 · p.1 #3 · SB800 TTL stopped working
Rico _ I'll do that tonight when I get home and hopefully, that's all that's needed to fix the TTL issue. Thanks for that advice.
Regards,
Tony
Jan 13, 2017 at 11:54 AM
Gregg Heckler
p.1 #4 · p.1 #4 · SB800 TTL stopped working
Depending on how much use and abuse it's seen I'd say it's lived a pretty long life for a $300 piece of electronics. But as Rico said, sometimes all it takes is clean contacts. Also, depending on the camera body (old D700) is could be the hot shoe itself. Clean the hot shoe contacts also.
Jan 13, 2017 at 02:54 PM
Tony Admana
p.1 #5 · p.1 #5 · SB800 TTL stopped working
Gregg,
Thanks for the response. I'll let you guys know if it works.
Cheers,
Tony
Jan 13, 2017 at 03:47 PM
Tony Admana
p.1 #6 · p.1 #6 · SB800 TTL stopped working
Got home today and cleaned up the hotshoe/contacts and still the same issue with TTL. The SB800 fires but the image is almost pitch black. Tho' it still works with M/RPT/A modes.
Jan 13, 2017 at 05:17 PM
