arduluth Offline Upload & Sell: Off
p.1 #14 · p.1 #14 · A Question of Perspective Compression on Different Sensor Sizes | |
WhyFi wrote:
If you're not moving, your perspective isn't changing, regardless of sensor format, focal length, FoV, etc. The position of the camera relative to the subject is the only thing that influences perspective.
Exactly. If you have an A7 with a 70-200mm zoom and take one photo at 70mm, zoom in, and take another at 200mm. The 70mm and 200mm photos will have the same perspective and the same amount of compression. Since you didn't move, the 200mm shot will have less in the frame than the 70mm shot, but that's a different kettle of fish than perspective.
Same with your A7+85mm and A6000+55mm. The field of view will be marginally wider on the A6000+55mm, but perspective and compression will be the same.
