Archive 2016 · Convert Kacey Beauty dish to Bowens mount?
jzucker
p.1 #1 · p.1 #1 · Convert Kacey Beauty dish to Bowens mount?
I currently have the buff mount on it. I didn't see an option for Bowens mount so I emailed them 4-5 days ago and never heard back so I assume they don't officially support it. Anyone do this conversion?
Dec 07, 2016 at 02:42 PM
AlphaPhotography
p.1 #2 · p.1 #2 · Convert Kacey Beauty dish to Bowens mount?
How do your like your Kacey dish and how long did it take to receive it? It seems the site always says a 4-6 week wait for them. Is this accurate? Thanks
Dec 08, 2016 at 04:23 AM
jzucker
p.1 #3 · p.1 #3 · Convert Kacey Beauty dish to Bowens mount?
i like it a lot. Mola performance without the cost. I'm a bit disappointed that he didn't get back to my inquiry though. I'll probably buy a cheap bowens ring and drill holes in it.
Dec 08, 2016 at 12:30 PM
hijazist
p.1 #4 · p.1 #4 · Convert Kacey Beauty dish to Bowens mount?
I converted my Mola Demi using a generic Bowens speedring, the dedicated one was $70. Just make sure you get a speedring that lays flat on the dish (Assuming that the Kacey BD has the same design as the Mola).
Dec 09, 2016 at 09:24 AM
jzucker
p.1 #5 · p.1 #5 · Convert Kacey Beauty dish to Bowens mount?
which generic ring did you use? All the ones I see are really deep and with the design of the Godox flash tube, it would put the tube behind the dish.
Dec 09, 2016 at 12:02 PM
BigIronCruiser
p.1 #6 · p.1 #6 · Convert Kacey Beauty dish to Bowens mount?
I bought one of these speedrings to use with a PCB beauty dish. It was too deep for a bare-bulb flash, so I cut off the flange, and then used epoxy to affix it to the BD. It will not come off.
Dec 09, 2016 at 01:54 PM
jzucker
p.1 #7 · p.1 #7 · Convert Kacey Beauty dish to Bowens mount?
how did you cut it off? With a sawzall? I'd love to see a picture of how you cut it and glued it.
I was thinking of getting this one. It looks a little easier to drill and work with. It's not as deep as the one you listed or the fotodiox ones that I have. I'm thinking I could mount it from the inside of the dish to gain a minimize the depth a little more.
http://www.adorama.com/glsrpopbo.html?utm_medium=Shopping%20Site&utm_source=dealtime
Dec 09, 2016 at 02:14 PM
BigIronCruiser
p.1 #8 · p.1 #8 · Convert Kacey Beauty dish to Bowens mount?
This particular adapter was pretty easy to cut with a hacksaw. The edge was then filed to ensure that it would lay flat against the back of the BD. fyi/The small holes are the result of trying a different adapter that had been attached with screws.
Dec 10, 2016 at 07:06 AM
jzucker
p.1 #9 · p.1 #9 · Convert Kacey Beauty dish to Bowens mount?
how did you make a sturdy epoxy connection on such a thin edge?
Dec 12, 2016 at 02:43 AM
Michael White
p.1 #10 · p.1 #10 · Convert Kacey Beauty dish to Bowens mount?
Have you thought of an adapter your mount to bowens? Check ebay they seam to have all configurations of adapters.
I got a bowens to elichrom I think is the correct terminology adapts my bowens mount modifiers to work with mt quadra lights using the elinchrom adapter. I have a bowens mount beauty dish that I got several years ago around 09
Dec 12, 2016 at 06:21 AM
jzucker
p.1 #11 · p.1 #11 · Convert Kacey Beauty dish to Bowens mount?
With an adapter i'd have a problem where the flash tube wouldn't be inside the dish.
Dec 12, 2016 at 11:08 AM
jzucker
p.1 #12 · p.1 #12 · Convert Kacey Beauty dish to Bowens mount?
i wonder if this would work?
https://www.amazon.com/Glow-Adapter-HexaPop-Softboxes-Lumedyne/dp/B00S5ULQG4/ref=sr_1_3?ie=UTF8&qid=1481573811&sr=8-3&keywords=glow+pop+softbox
Dec 12, 2016 at 08:19 PM
jzucker
p.1 #13 · p.1 #13 · Convert Kacey Beauty dish to Bowens mount?
bigironcruiser, i got the speedring that you linked to but the flange is angled about 30%. How did you get yours to lie flat? Or are they made differently now? I misunderstood your original posting. I thought you hacksawed some of the depth off the space between the flange and the bowens mount and then glued that back on. I see what you did not but since my flange has the 30 degree angle, I'm not sure how I'd get a good connection to the BD.
Dec 21, 2016 at 12:52 PM
BigIronCruiser
p.1 #14 · p.1 #14 · Convert Kacey Beauty dish to Bowens mount?
The flange was completely removed with a hacksaw, then the cut edge was filed to get it as flat as possible. I smeared a fair bit of Loctite Metal/Concrete Epoxy on the BD, then set the adapter into the epoxy. I then squirted additional epoxy on the inside & outside of the adapter where it makes contact with the BD. I put a fairly heavy weight on the adapter until the epoxy had time to set. It's definitely there to stay.
Dec 22, 2016 at 03:17 AM
jzucker
p.1 #15 · p.1 #15 · Convert Kacey Beauty dish to Bowens mount?
so you took off the flange and the 1/8" rim? Could you post a picture of it on the dish? I kind of wonder if it could be glued to the inside of the dish without doing all that?
Dec 22, 2016 at 12:06 PM
BigIronCruiser
p.1 #16 · p.1 #16 · Convert Kacey Beauty dish to Bowens mount?
This is a rough sketch of what it looked like after removing (what I call) the flange.
Dec 22, 2016 at 01:11 PM
