Archive 2016 · Better adapter needed for Canon 24mm TSE II - suggestions?
gordorad
p.1 #1 · p.1 #1 · Better adapter needed for Canon 24mm TSE II - suggestions?
I have a Fotga adapter EF to Sony E adapter. After adding some flocking material, the adapter works pretty well...
Biggest issue I have is when using it with 24 and or 90mm TSE lenses, and the "limited" shifting that I can do before extreme vignetting sets in. (Usually about 5mm or so). I think this is caused by the overall thickness of the mount adapter. Any suggestions for adapters that allow for additional shifting without vignetting?
Using with a Sony A7R.
Thanks.
Gordon
Nov 30, 2016 at 10:25 AM
Admin
p.1 #2 · p.1 #2 · Better adapter needed for Canon 24mm TSE II - suggestions?
Thanks.
Gordon
Have you tried the Sigma MC-11? IMO, it's the most reliable electronic adapter for the E-mount as far as QC and tolerance goes.
Nov 30, 2016 at 11:02 AM
gordorad
p.1 #3 · p.1 #3 · Better adapter needed for Canon 24mm TSE II - suggestions?
I wasn't aware of it. I will look into it. Does it have a bigger "throat" allowing more shifting without vignetting?
Nov 30, 2016 at 11:36 AM
Gunzorro
p.1 #4 · p.1 #4 · Better adapter needed for Canon 24mm TSE II - suggestions?
I agree with Fred. I have the Sigma MC-11 (EF) and it works superbly with 17TSE and 24TSE II. No need to flock, and has the full range of movements, plus the electronic coupling for aperture and exif.
gordorad
p.1 #5 · p.1 #5 · Better adapter needed for Canon 24mm TSE II - suggestions?
Sounds like this is the adapter. Thank you for the info!
Nov 30, 2016 at 11:39 AM
gordorad
p.1 #6 · p.1 #6 · Better adapter needed for Canon 24mm TSE II - suggestions?
Is this the correct adapter for Canon EF mount? I've never heard of a Canon SGV??
https://www.amazon.com/Sigma-Mount-Converter-MC-11-Lenses/dp/B01C7A3W7S/ref=sr_1_1?ie=UTF8&qid=1480524099&sr=8-1&keywords=sigma+mc-11+canon+ef+to+sony+e
Nov 30, 2016 at 11:43 AM
navmannz
p.1 #7 · p.1 #7 · Better adapter needed for Canon 24mm TSE II - suggestions?
My TS-E 24 II works just fine with the Metabones IV - John
Nov 30, 2016 at 02:22 PM
LostBoyNZ
p.1 #8 · p.1 #8 · Better adapter needed for Canon 24mm TSE II - suggestions?
Same here, I was quite happy with the TS-E 24 II once I changed to the Metabones IV.
Nov 30, 2016 at 02:34 PM
mcbroomf
p.1 #9 · p.1 #9 · Better adapter needed for Canon 24mm TSE II - suggestions?
SGV = Sigma Global Vision. So this is saying that it's the adapter to use for your Sigma lenses for Canon (ie yes, it's the right one as the MC-11 is not advertised by Sigma for Canon brand EF lenses)
Travis Rhoads
p.1 #10 · p.1 #10 · Better adapter needed for Canon 24mm TSE II - suggestions?
Interesting, I might have to try it. I have not had issues with the 24TSEII, but the 17TSE gave me fits, the camera kept shutting off and resetting...might have to add the MC-11, I have a 50 ART to use it with too...
Nov 30, 2016 at 02:50 PM
gordorad
p.1 #11 · p.1 #11 · Better adapter needed for Canon 24mm TSE II - suggestions?
Excellent. Now my images will have a global look!!!
Nov 30, 2016 at 02:54 PM
fishjump
p.1 #12 · p.1 #12 · Better adapter needed for Canon 24mm TSE II - suggestions?
I used the metabones with my 17mm and the A7RII with no problems mechanically. However, when shifted, the picture suffered significantly in the corners.
Nov 30, 2016 at 03:34 PM
notherenow
p.1 #13 · p.1 #13 · Better adapter needed for Canon 24mm TSE II - suggestions?
I have never had any issue with the Metabones IV on either 17 TS-E or 24 ii TS-E and an A7s and original A7 (24 and A7 both since sold).
I have also used a couple of other adapters, including a cheap no name as a back up (it stopped working for AF with AF lenses but started working like a Metabones IV with MF lenses.
The Metabones iv has a larger "hole" made specifically for the TS lenses.
Nov 30, 2016 at 09:06 PM
navmannz
p.1 #14 · p.1 #14 · Better adapter needed for Canon 24mm TSE II - suggestions?
I did have problems like this but they disappeared with the latest Metabones firmware upgrade...
Nov 30, 2016 at 09:40 PM
Travis Rhoads
p.1 #15 · p.1 #15 · Better adapter needed for Canon 24mm TSE II - suggestions?
I probably need to.update the adapter then...been a while since I did that.
Nov 30, 2016 at 10:02 PM
sbay
p.1 #16 · p.1 #16 · Better adapter needed for Canon 24mm TSE II - suggestions?
Does anybody know how the MC-11 compares to the MB IV (flocked or unflocked)?
I'm using the MB IV flocked with the 24mm TSE II and 45MM TSE and it seems fine but I don't have a 5dsr to test to see exactly what I'm losing with the MBIV + A7R2 combo.
Dec 02, 2016 at 04:49 PM
PhotoMaximum
p.1 #17 · p.1 #17 · Better adapter needed for Canon 24mm TSE II - suggestions?
I have a new A7RII and the Metabones IV. I just did some product photography using tilt and played with shift on the 45 TS-E and had no issues. Also did a couple of quick tests using the 24 TS-E mkII and all looked good as well...
Dec 02, 2016 at 05:18 PM
PhotoMaximum
p.1 #18 · p.1 #18 · Better adapter needed for Canon 24mm TSE II - suggestions?
^^ I also have a new Canon 5D mkIV and plan on doing a full test against the A7RII using the new 17 and 24 TS-E lenses. Hopefully this weekend...
Dec 02, 2016 at 05:21 PM
secondclaw
p.1 #19 · p.1 #19 · Better adapter needed for Canon 24mm TSE II - suggestions?
I use metabones IV model T (pretty important as it has improvements for ts lenses) with ts-e 17 without issues, even at pretty extreme shift.
Dec 04, 2016 at 07:47 PM
gordorad
p.1 #20 · p.1 #20 · Better adapter needed for Canon 24mm TSE II - suggestions?
The Sigma adapter arrives soon. I will post an update.
Dec 04, 2016 at 09:25 PM
