JBPhotog Offline Upload & Sell: Off
You only need to cover the flash tube to gel any large modifier, umbrella, soft box, octa etc. Any clip or clamp that holds the gel is the one that works, no one particular model is best in all circumstances. That's why one wants to have a few options, small spring clips easily hold a gel to a speed ring in a soft box for example, I use small pony clamps, whereas they are a bit big to clip to a rib. A simple binder clip from a stationary shop will clip to a rib or the rim of a metal reflector and they are cheap and plentiful.
