Archive 2016 · Nikon 200mm f/4 Micro with TC
p.1 #1 · p.1 #1 · Nikon 200mm f/4 Micro with TC
I see that the 200mm f/4 micro is not compatible with the newer TCs.
I am wondering if anyone would know if there would be an issue putting a extension tube between the lens and TC .
So you would have TC, tube and then lens.
I am trying to get at more than 1:1 . Stacking all three Kenko tubes really is not adding all that much since it is a long focal length .
Another thought is trying 2 Kenko 36mm tubes . I have tried to research, but can't find anything.
If I am going down the wrong path, just let me know.
Appreciate any ideas on this.
Thanks
Nov 05, 2016 at 04:49 PM
Chris Court
p.1 #2 · p.1 #2 · Nikon 200mm f/4 Micro with TC
If I want more magnification on the 200 I screw in the 5T or 6T (or both). Not sure of the exact magnification ratios with these (should be googleable), but it's considerably more than 1:1, and IQ remains high.
C
Nov 05, 2016 at 11:12 PM
p.1 #3 · p.1 #3 · Nikon 200mm f/4 Micro with TC
Thank you so much Chris, appreciate it. Now going to try and find these.
Nov 06, 2016 at 02:49 AM
joefoo
p.1 #4 · p.1 #4 · Nikon 200mm f/4 Micro with TC
I tried to put my tubes on my TC but the protruding front element of the TC wouldn't fit into the tube. My tubes have the electrical contacts on them, maybe other tubes have a bigger diameter throat?
Nov 06, 2016 at 03:56 AM
