Archive 2016 · Having problem with fps on D3S
graham_martin
p.1 #1 · p.1 #1 · Having problem with fps on D3S
All of a sudden I can't get my D3s to shoot at more than 2 or 3 frames per second. I have control d2 set to Continuous High Speed 11 fps. I have the camera in AF-C mode (which I don't think has any effect on fps), and the control dial set to Ch. I have the camera set to Back Button Focus, and the shutter to "Release." I have tried simply depressing the shutter button to see what happens, and I still only get 2 or 3 fps. I turned off Active D Lighting in the shooting menu, because if you have it on, it apparently reduces the fps in burst mode.
I did a factory reset, but that didn't help.
Oct 31, 2016 at 01:11 AM
hjanssen
p.1 #2 · p.1 #2 · Having problem with fps on D3S
Is the shutter speed short enough for high fps?
Oct 31, 2016 at 10:19 AM
graham_martin
p.1 #3 · p.1 #3 · Having problem with fps on D3S
I was shooting at 1/1250 second and, until yesterday, have not had any problem with getting 11 fps.
Oct 31, 2016 at 11:54 AM
trenchmonkey
p.1 #4 · p.1 #4 · Having problem with fps on D3S
Bracketing on??
Oct 31, 2016 at 12:28 PM
graham_martin
p.1 #5 · p.1 #5 · Having problem with fps on D3S
Will, you are a flaming genius! I did have the bracketing activated. I just turned it off, and it's working fine now. Thank you so much.
Oct 31, 2016 at 01:17 PM
trenchmonkey
p.1 #6 · p.1 #6 · Having problem with fps on D3S
My pleasure, Graham! Probably why Fred still keeps me around.
Oct 31, 2016 at 02:32 PM
DGC1
p.1 #7 · p.1 #7 · Having problem with fps on D3S
trenchmonkey wrote:
Bracketing on??
I hate it when he does this...
Oct 31, 2016 at 02:52 PM
monochrome
p.1 #8 · p.1 #8 · Having problem with fps on D3S
Damn, know that feeling!
Oct 31, 2016 at 06:42 PM
Blakehfreeman
p.1 #9 · p.1 #9 · Having problem with fps on D3S
If it helps: when Nikon ships repaired lenses back (to me at least) they send them back with the AF/M switch in manual mode... and I always freak out and assume they sent me a broken lens back..
Nov 03, 2016 at 12:09 AM
