Archive 2016 · TechArt Pro - any cases fit the camera with the TAP fitted?
oofoto
p.1 #1 · p.1 #1 · TechArt Pro - any cases fit the camera with the TAP fitted?
TechArt Pro - any cases fit the camera with the TAP fitted? My Gariz is juuust too thick.
Oct 26, 2016 at 05:21 PM
Slalom
p.1 #2 · p.1 #2 · TechArt Pro - any cases fit the camera with the TAP fitted?
I use a medium size SLR neoprene case for packing.
It holds the A7RII, An L bracket, the TAP, L/M to SLR adapter and a compact Slr lens(WA) I wish to take out.
Then add a compatible medium zoom and a light telephoto and go off hiking
Oct 26, 2016 at 10:41 PM
iskraII
p.1 #3 · p.1 #3 · TechArt Pro - any cases fit the camera with the TAP fitted?
TP brand half case works well if you remove the small decorative piece near the bottom. The bottom of the case is thick enough it flushes with TAP
Oct 27, 2016 at 12:03 AM
