Multicontroller
drew.bowser
p.1 #1 · p.1 #1 · Multicontroller
Does your multi controller joystick make adjustments at the slightest touch or does it take a full clicking movement to any direction to cause it to activate?
My 5D3 multi controller is SOO sensitive I am constantly changing the AF points and its driving me crazy.
Thinking about sending it to canon for replacement
What is the normal service rate anymore for canon service? I know it changes every few years...
Oct 25, 2016 at 04:11 PM
qc_mountain
p.1 #2 · p.1 #2 · Multicontroller
My 5D2 needed a good push to make the changement my 2 copy of the 7DII was normal , and my 5DsR is a bit sensible if i compare to my 5D2.
It sound's like yours need to be replaced.
Francois
Oct 25, 2016 at 04:34 PM
riokid
p.1 #3 · p.1 #3 · Multicontroller
As of last week, the "standard out of warranty labor charge" was $219. They might also charge for any needed parts.
HTH
Oct 25, 2016 at 04:50 PM
WkDave
p.1 #4 · p.1 #4 · Multicontroller
Just FYI, replacing the multi controller involves replacing the entire back panel. Don't remember the cost off the top of my head.
Oct 25, 2016 at 09:20 PM
scalesusa
p.1 #5 · p.1 #5 · Multicontroller
$150 for a new back from Ebay, easy to replace, but you should have JIS screwdrivers to avoid ruining screw heads. Those screws are not Phillips.
http://www.ebay.com/itm/Canon-5D-mark-III-rear-Back-Cover-Housing-Plate-Repair-Part-CY3-1653-/331888554944?hash=item4d461973c0:gYwAAOSwcwhVP95P
Oct 26, 2016 at 04:07 PM
