silverbird Offline Upload & Sell: Off
jforkner wrote:
According to heavens-above.com, the ISS would have been visible over northern MI on 10/10/16 at 19:53 hours for about 7 minutes at a max. altitude of 25º moving from WNW to NE. You’ll have to determine if that fits.
Normally an aircraft will show up as a red & white (or just white) series of dots as its flashing lights create a path across the sky.
A meteor will usually show up as a streak with a taper at one or both as it increases, then dies in brightness.
A satellite (e.g., the ISS) will usually show up as a thin line with no interruptions for the duration of the exposure (or during its period of visibility).
Jack...Show more →
That matches the time and direction the photograph was taken.
It was taken at 24mm focal length, exposure was f 2.8, 30 seconds, ISO 1600.
I was in the northern portion on the lower peninsula of Michigan.
The ISS was over the northern shore of Lake Superior. (quite a distance from where the shot was taken)
Thanks,
John
