Archive 2016 · Setting IBIS focal length with manual lens?
LostBoyNZ
p.1 #1 · p.1 #1 · Setting IBIS focal length with manual lens?
Apologies if this is a newbie question (I tried looking through some past posts here) but when I mount a lens which has no electrical contact to the A7R II, the option to set the focal length for IBIS is greyed out.
Am I doing something wrong, or is there a trick to being able to tell it the focal length?
Thanks!
Oct 14, 2016 at 08:41 AM
Dave Good
p.1 #2 · p.1 #2 · Setting IBIS focal length with manual lens?
I have the A7II and have select Manual for SS Adjust then set the SS Focal Length, then saved it in the Memory menu. With one adapted lens set to 1 and one non-native m/f lens set to 2 lens changes are recognized. Not sure if this was necessary but it works, should work on the "R" as well.
Oct 14, 2016 at 12:11 PM
Kingfishphoto
p.1 #3 · p.1 #3 · Setting IBIS focal length with manual lens?
On my 7R11, i turn on steady shot and the steady shot settings is illuminated so you can
enter the lens focal length.
Oct 14, 2016 at 04:06 PM
LostBoyNZ
p.1 #4 · p.1 #4 · Setting IBIS focal length with manual lens?
Thanks, I was trying to use Steady Shot Adjust, which would always come up with an error that the lens was not connected, but I see steady shot focal length is a separate option. Thanks
Oct 14, 2016 at 09:34 PM
