Archive 2016 · RRS - B6D: Plate for 6D ( Works with other cameras ? )
PIOK
p.1 #1 · p.1 #1 · RRS - B6D: Plate for 6D ( Works with other cameras ? )
Anyone use this Really Right Stuff plate " B6D: Plate for 6D "
with other cameras like 5Ds or 5d4 ?
http://www.reallyrightstuff.com/B6D-Plate-for-6D?fragment=%2FB6D-Plate-for-6D&_ga=1.116819142.1760711064.1470400939&lang=en_US
I have an "L" Plate for Nikon D810 which fits D600 very well.
Thinking if I get this plate for Canon 6D > if one day in case of update I will be able to use with other canon cameras
Oct 13, 2016 at 08:26 PM
EB-1
p.1 #2 · p.1 #2 · RRS - B6D: Plate for 6D ( Works with other cameras ? )
Have you asked RRS? They should respond within a day or less.
Oct 13, 2016 at 11:27 PM
Roland W
p.1 #3 · p.1 #3 · RRS - B6D: Plate for 6D ( Works with other cameras ? )
The custom bottom only plate for the 6D that you linked to might happen to fit a few other cameras, but you should not count on it. If you want to use a bottom only plate on multiple cameras, then consider the multipurpose plate that Really Right Stuff sells, that will likely work fine on the 6D. It has two slots, and those slots allow it to fit on many cameras and still bring the raised edge up against the camera body. You should check with them to make sure it clears the battery door when used in one of the two slots, but it probably will..
http://www.reallyrightstuff.com/BP-CS-Multi-camera-conventional-plate
I much prefer the custom contoured plates that are camera specific, and also very much prefer L plates for my cameras. But a bottom only plate is still very useful.
Oct 14, 2016 at 05:19 AM
Gochugogi
p.1 #4 · p.1 #4 · RRS - B6D: Plate for 6D ( Works with other cameras ? )
A few years back I bought a RRS L-plate for my 70D and it fit like a glove. I recently got an 80D, a camera that uses the same battery grip as the 70D, and I was surprised to find the RRS plate didn't fit the 80D. RRS plates are so tightly fitted even a tiny change in camera contour will render it obsolete. RRS also changed the removable L-component so it can't be shared with older plates.
Oct 15, 2016 at 03:07 AM
PIOK
p.1 #5 · p.1 #5 · RRS - B6D: Plate for 6D ( Works with other cameras ? )
Thank You for some info. I did order B6D: Plate for 6D
I have L Plate for Nikon D810 - amazing piece, but need one cheaper for my Canon 6D to use with my BH-40
This time I want to travel with small kit. So 6D with 16-35 f4 + 70-200 f4 is like a dream set
Oct 15, 2016 at 04:50 AM
