Konablue Offline Upload & Sell: Off
Before the B1/B2 systems that I use now, I had the D1 500w and 1000w strobes. I found I often needed to use the lower end of the power level of a 500w more often than the max setting of a 1000w (usually, to get a narrower DOF and I rarely shot with strobes in bright conditions. Something I discovered between the two strobes was that the 1000w D1 did not dial down on the power as low as the 500w. So I wonder if you can dial the power down as low on the new 1000w D2 as you can on any of the new or old 500w or 250w models?
Note: The D2 has a 10 stop range whereas the D1's had 7 stops and the B1 has 9. The specs on their website doesn't give you any info on the lower limits of these strobes.
So does anyone happen to know how the D2's minimum power level compare to the D1/B1 models? Can the D2 go as low?
