       2       3       4       end
Archive 2016 · TDP test of EF16-35mm f/2.8L III now available
Photonadave
p.1 #1 · p.1 #1 · TDP test of EF16-35mm f/2.8L III now available
The TDP lens test for the new EF16-35mm f/2.8L III compared to the older version II is now available& posted here.
And when compared to the f/4L IS see here.
The results look amazing!
The new lens seems to perform best at 16mm however appears to vignette more wide open at that focal length compared to the older version II lens. The performance difference is less noticeable at other focal lengths.
Edited on Oct 12, 2016 at 08:19 AM · View previous versions
Oct 12, 2016 at 07:39 AM
jhg photo
p.1 #2 · p.1 #2 · TDP test of EF16-35mm f/2.8L III now available
Thanks for telling us. Impressive lens.
Oct 12, 2016 at 08:18 AM
Gust
p.1 #3 · p.1 #3 · TDP test of EF16-35mm f/2.8L III now available
my dear, what a difference
amazing
Oct 12, 2016 at 09:45 AM
pcho
p.1 #4 · p.1 #4 · TDP test of EF16-35mm f/2.8L III now available
I have a copy of the lens and I am very impressed with corner sharpness at 16mm and F2.8. It's so much better than my mkll.
Oct 12, 2016 at 10:09 AM
p.1 #5 · p.1 #5 · TDP test of EF16-35mm f/2.8L III now available
Awesome performance at f/2.8.
Oct 12, 2016 at 11:35 AM
dehowie
p.1 #6 · p.1 #6 · TDP test of EF16-35mm f/2.8L III now available
Nice looking lens if you need the 2.8 but at F4 they look almost identical and one ha a brilliant stabiliser.
As much as I love buying new glass I can't see a reason as I don't need the 2.8 that wide.
nice looking lens but not for me...
Oct 12, 2016 at 11:43 AM
Pixel Perfect
p.1 #7 · p.1 #7 · TDP test of EF16-35mm f/2.8L III now available
Massively better than the mk II, but not so much better than the f/4L IS, which looks like a bargain.
Oct 12, 2016 at 11:46 AM
gvg45
p.1 #8 · p.1 #8 · TDP test of EF16-35mm f/2.8L III now available
Canon's on a roll with the performance of these new lenses.
Oct 12, 2016 at 12:25 PM
Brea
p.1 #9 · p.1 #9 · TDP test of EF16-35mm f/2.8L III now available
Corner performance is way better at 2.8 than the F4 is on F4, but still not worth over double the premium.
Oct 12, 2016 at 01:13 PM
RobertLynn
p.1 #10 · p.1 #10 · TDP test of EF16-35mm f/2.8L III now available
As much as I love 2.8, I think I'll be buying the f/4is.
The times I use 2.8 and ultra wide are so minimal that I would suck it up, bump the iso, or lower the speed to get it with the f/4.
I considered selling my mk2 and buying the 3, but I think I'll sell and buy the is.
Oct 12, 2016 at 01:29 PM
Marco
p.1 #11 · p.1 #11 · TDP test of EF16-35mm f/2.8L III now available
For astrophotography, where corner to corner sharpness is important wide open, I'd say this is an impressive lens.
According to TDP neither the 11-24L nor the 14L II can reach the corner performance of this new zoom at 16mm f/2.8... not even the Zeiss Milvus 21!
But yes, the f/4L IS is still an excellent lens at a bargain price.
Oct 12, 2016 at 03:22 PM
gdanmitchell
p.1 #12 · p.1 #12 · TDP test of EF16-35mm f/2.8L III now available
The new lens looks excellent.
Looks like the f/2.8 lens has a small advantage at the largest apertures, but is roughly the same at smaller apertures. Folks who need f/2.8 will like it, though folks who mostly do stuff like landscape may not find it to be a great value given the outstanding performance (and lower price and smaller size) of the f/4 lens.
Oct 12, 2016 at 03:34 PM
jcunwired
p.1 #13 · p.1 #13 · TDP test of EF16-35mm f/2.8L III now available
These results are impressive indeed.
I'd like to see a comparison between the Canon and Tamron 15-30mm f/2.8 VC before my Tamron sells!
Oct 12, 2016 at 04:15 PM
hotdog12
p.1 #14 · p.1 #14 · TDP test of EF16-35mm f/2.8L III now available
Wow! I was comparing it to the 16-35 f/4L IS at f/4 and, dang, that is a sweet lens.
Oct 12, 2016 at 04:31 PM
artificialyello
p.1 #15 · p.1 #15 · TDP test of EF16-35mm f/2.8L III now available
It's not a bargain! It's f/4 (four!) and though it has IS it will not produce as shallow DOF nor will it have as pleasant bookeh, if the Canon MTFs are right.
You go ahead and tell Canon to jack up the price on this second tier semipro lense! ;-ppp
Oct 12, 2016 at 06:19 PM
Schlotkins
p.1 #16 · p.1 #16 · TDP test of EF16-35mm f/2.8L III now available
wow that's impressive. If coma is good... this would make a great astro Lens.
Oct 12, 2016 at 06:25 PM
gdanmitchell
p.1 #17 · p.1 #17 · TDP test of EF16-35mm f/2.8L III now available
It is a "bargain" if you don't do the sort of photography that requires f2.8 at ultra wide focal lengths and which may benefit from IS.
Edited on Oct 12, 2016 at 10:14 PM · View previous versions
Oct 12, 2016 at 06:42 PM
pcho
p.1 #18 · p.1 #18 · TDP test of EF16-35mm f/2.8L III now available
All I can say is I tested the mklll and Ziess 15mm at F2.8 with the brick wall test and I struggle to differtiate between the 2. Remember the the mklll is a zoom and the Zeiss is a prime lens.
Oct 12, 2016 at 07:50 PM
Tom_W
p.1 #19 · p.1 #19 · TDP test of EF16-35mm f/2.8L III now available
As a 16-35 Mk II owner, all I can say is WoW!
Oct 12, 2016 at 07:59 PM
whumber
p.1 #20 · p.1 #20 · TDP test of EF16-35mm f/2.8L III now available
Unfortunately the 16-35III is only tested on the 5DsR while the 15-30 was tested on the 1Ds3, but the difference is pretty clear.
TDP - 16-35III vs Tamron 15-30
Oct 12, 2016 at 08:02 PM
       2       3       4       end
       2       3       4       end
