Archive 2016 · One of the backyard denizems
MedicineMan404
p.1 #1 · p.1 #1 · One of the backyard denizems
Sharpening was LRcc default.
With leaves of five by MedicineMan4040, on Flickr
Oct 11, 2016 at 11:40 PM
p.1 #2 · p.1 #2 · One of the backyard denizems
Excelent image Robert
Oct 12, 2016 at 12:18 AM
Karl Witt
p.1 #3 · p.1 #3 · One of the backyard denizems
Plenty sharp at default setting. Good light in the eye, those are some sharp looking toe nails!
Karl
Oct 12, 2016 at 02:17 AM
MedicineMan404
p.1 #4 · p.1 #4 · One of the backyard denizems
Thanks Karl. Thanks Morris.
Is there ever a situation when you want to decrease sharpness.
I just let LR do it's thing, should I sometime consider sliding the sharpness slider to less than default?
Robert
Oct 12, 2016 at 03:33 AM
surfnron
p.1 #5 · p.1 #5 · One of the backyard denizems
Very well done Robert. The sharpness looks very good. I would not worry about the default settings because what the image looks like is what counts. Try moving the slider to max sharpness - that should look very bad. Now move it back until the sharpness looks good. That's where you want it.
Be careful because slightly over-sharpened detail has a bright look in the fine detail, and you want to avoid that.
The problem is that what looks good is somewhat subjective...
Anyway, here are some examples to show what I think is correct. You, (or anyone else ), is free to disagree with me. 1 has no sharpening, 2 is way over-sharpened, and 3 looks good to me. I took 2 too far to emphasize the over-sharpening. You can see that the fine detail has an un-natural brightness to it. I try to stop before the fine detail starts to brighten too much. This shot doesn't show it, but if you have a dark subject against a bright bg, you can easily get sharpening halos. And if you have a bright subject against a dark bg, the halos will be on the subject - not the bg.
Anyway, I hope this helps ~ Ron
surfnron 2016
1- no sharpening
surfnron 2016
2- over-sharpened - notice how the white spots around the eye are very bright and the fine detail just above the tail is bright
surfnron 2016
3- what looks good to me. The spots around the eye and the detail above the tail look more natural
Oct 12, 2016 at 12:56 PM
BeeBalm
p.1 #6 · p.1 #6 · One of the backyard denizems
Your lady Cardinal looks beautiful!
BB
Oct 13, 2016 at 12:47 AM
