Archive 2016 · Sigma 150-600mm C vs. Tamron 150-600mm
cameron12x
p.1 #1 · p.1 #1 · Sigma 150-600mm C vs. Tamron 150-600mm
Perhaps I haven't been using the search feature well enough, but what is the general verdict when comparing these two zooms? TIA.
Oct 08, 2016 at 03:29 AM
EB-1
p.1 #2 · p.1 #2 · Sigma 150-600mm C vs. Tamron 150-600mm
The Tamron has only been out for one week, so you will have to wait a bit for some test results.
Oct 08, 2016 at 03:35 AM
Imagemaster
p.1 #3 · p.1 #3 · Sigma 150-600mm C vs. Tamron 150-600mm
cameron12x wrote:
Perhaps I haven't been using the search feature well enough, .........
You're not kidding.
http://www.fredmiranda.com/forum/topic/1369515/0?keyword=150-600#13049817
http://www.fredmiranda.com/forum/topic/1367857/0?keyword=150-600#13035804
http://www.fredmiranda.com/forum/topic/1365810/0?keyword=150-600#13018679
http://www.fredmiranda.com/forum/topic/1360174/0?keyword=150-600#12968409
http://www.fredmiranda.com/forum/topic/1354214/0?keyword=150-600#12917926
Oct 08, 2016 at 04:54 AM
Imagemaster
p.1 #4 · p.1 #4 · Sigma 150-600mm C vs. Tamron 150-600mm
What makes you think he is asking about the new Tamron
Oct 08, 2016 at 04:55 AM
EB-1
p.1 #5 · p.1 #5 · Sigma 150-600mm C vs. Tamron 150-600mm
It seems odd to look for the obsolete version now, but I suppose anything is possible.
Oct 08, 2016 at 05:01 AM
Imagemaster
p.1 #6 · p.1 #6 · Sigma 150-600mm C vs. Tamron 150-600mm
Gee, I guess it is odd that people buy used (obsolete) gear. Where do you think most obsolete photo gear goes?
Oct 08, 2016 at 05:18 AM
EB-1
p.1 #7 · p.1 #7 · Sigma 150-600mm C vs. Tamron 150-600mm
I have a couple dozen lens and a bunch of DSLRs in the closets. I assume eventually they will go to the electronic waste recycling.
Oct 08, 2016 at 05:25 AM
johnctharp
p.1 #8 · p.1 #8 · Sigma 150-600mm C vs. Tamron 150-600mm
The new version is 50% more than the old version and the Sigma | C, so...
To answer the OP's question, the Sigma | C is largely superior, not so much more as just better a little in every way. I purchased it instead of the OG Tamron for this reason, and for its price, I am quite satisfied.
However, the G2 Tamron (if you can get over Tamron's unergonomic zoom direction) does make a good upgrade in that it is likely at least as good as the Sigma | C optically and in terms of AF and stabilization (you'll want to check reviews as they come available to be sure), while adding weather sealing but not the extra size and weight as seen in the Sigma | S.
Oct 08, 2016 at 05:49 AM
EB-1
p.1 #9 · p.1 #9 · Sigma 150-600mm C vs. Tamron 150-600mm
Perhaps this will prompt Sigma to redesign a better, yet lighter 150-600 S.
Oct 08, 2016 at 05:54 AM
johnctharp
p.1 #10 · p.1 #10 · Sigma 150-600mm C vs. Tamron 150-600mm
And cheaper?
Yes, that'd be nice too .
Oct 08, 2016 at 06:13 AM
Pixel Perfect
p.1 #11 · p.1 #11 · Sigma 150-600mm C vs. Tamron 150-600mm
Sigma sports to justify the ridiculous weight needs to be a true f/5.6 lens, but I suspect they could do that and still make it lighter. Things like getting rid of the metal hood and using a lightweight plastic would save almost 0.5kg alone. If it remains f/6.3 it should aim at no more than 2.3-2.4kg. Given that the new Sigma 500 f/4 is almost as light as the Canon, Sigma looks to have turned a corner in telephoto weight, so I live in hope.
Sigma C is very good, but I like the look of the Tamron G2 has a a couple of nice features and build is better than Sigma C.
Oct 08, 2016 at 08:54 AM
Pixphatic
p.1 #12 · p.1 #12 · Sigma 150-600mm C vs. Tamron 150-600mm
Pixel Perfect wrote:
Sigma sports to justify the ridiculous weight needs to be a true f/5.6 lens,but I suspect they could do that and still make it lighter. Things like getting rid of the metal hood and using a lightweight plastic would save almost 0.5kg alone. If it remains f/6.3 it should aim at no more than 2.3-2.4kg. Given that the new Sigma 500 f/4 is almost as light as the Canon, Sigma looks to have turned a corner in telephoto weight, so I live in hope.
Very interesting thought,which I too feel the same way.
From the basic calculations (learnt from this forum), as the filter size is huge 105mm for the sports, the F-stops comes to 600/105 = 5.71 , which is very close to 5.6. Or for that matter, if it were to be 588mm ( only 12mm short of a true 600mm), it could have been a true 5.6 lens.
Very strange to find it termed as a '6.3' lens either way.
In future if any 600mm/f5.6 zoom lens is released, the filter size might be again at or near 105mm. This might also be true as the 105mm sized filter is the largest one to be found .(Plz correct me if I am mistaken)
Oct 08, 2016 at 10:44 AM
Snopchenko
p.1 #13 · p.1 #13 · Sigma 150-600mm C vs. Tamron 150-600mm
Why not do a big sale and earn a chunk of cash? I know it may not be a consideration for some people, but still... The B&S forum beckons.
Oct 08, 2016 at 10:57 AM
arbitrage
p.1 #14 · p.1 #14 · Sigma 150-600mm C vs. Tamron 150-600mm
The filter size doesn't correspond exactly to the front element size. If you look at the 150-600 lens you will see the it continues to taper outwards past the front element. The filter is 105 but the element is likely closer to 95 which it would be for a 600 6.3.
Oct 08, 2016 at 01:14 PM
qc_mountain
p.1 #15 · p.1 #15 · Sigma 150-600mm C vs. Tamron 150-600mm
In screw type filter it can go up to 138mm size .
Francois
Oct 08, 2016 at 01:56 PM
EB-1
p.1 #16 · p.1 #16 · Sigma 150-600mm C vs. Tamron 150-600mm
johnctharp wrote:
And cheaper?
Not for me. I'd prefer a sharper and more expensive lens that doesn't need to be replaced every few years. I think ~$3K would be a realistic price.
Oct 08, 2016 at 02:08 PM
Pixphatic
p.1 #17 · p.1 #17 · Sigma 150-600mm C vs. Tamron 150-600mm
Thanks Sir, point taken.
So,should that mean in reality that huge 105mm optical 'opening' isn't contributing to the IQ of the lens.??
On the contrary,I felt the IQ of the Sports seems to be better due to it's 105mm opening ( enabling better light gathering). I think read abt this somewhere..
Also anyone intending to put a sort of protective filter (I guess..??) would also have to invest quite a bit of amount.
Another thing is that for those other (600mm f6.3 zooms) having 95mm filter size isn't loosing anything, or for them the light gathering even lesser ?
Francois
Thanks Francois.....I was unaware of that.Must be very costly.
Thanks friends again. So much to learn from this forum.
Anindya.
Oct 08, 2016 at 03:38 PM
Imagemaster
p.1 #18 · p.1 #18 · Sigma 150-600mm C vs. Tamron 150-600mm
Until a number of people have bought and used the new Tamron (and posted samples), we will not know if the IQ or AF is any better than version 1, or the Sigma C.
Oct 08, 2016 at 04:54 PM
Pixel Perfect
p.1 #19 · p.1 #19 · Sigma 150-600mm C vs. Tamron 150-600mm
The larger glass will certainly help minimise vignetting wide open, it's collecting more light from highly skew rays.
I would never use a filter on this sort of lens however, so the cost of such large filters never worries me. I'd prefer a rear mounted one like in the superteles.
Oct 09, 2016 at 12:18 AM
EB-1
p.1 #20 · p.1 #20 · Sigma 150-600mm C vs. Tamron 150-600mm
The minimum front element size would be about 95 mm to achive f/6.3 at 600 mm. That does not mean a 600 mm lens with 105 mm front glass has an aperture of less than f/6.3.
For example, the first 80-200/2.8 Nikkor had a 95 mm filter.
Oct 09, 2016 at 12:39 AM
