Archive 2016 · New firmware out - Xpro1/2, lots of lenses
TheEmrys
p.1 #1 · p.1 #1 · New firmware out - Xpro1/2, lots of lenses
Lens updates seem to be paralax OVF voodoo. But the Xpro1 got an update! Cool deal, Fuji!
http://www.fujifilm.com/support/digital_cameras/software/fw_table.html
Oct 06, 2016 at 01:32 AM
rbf_
p.1 #2 · p.1 #2 · New firmware out - Xpro1/2, lots of lenses
FW update party!
Oct 06, 2016 at 01:35 AM
Edward Castro
p.1 #3 · p.1 #3 · New firmware out - Xpro1/2, lots of lenses
Just remember folks, if you have an important photography session coming up and your camera is working fine, hold off on doing the update.
Oct 06, 2016 at 01:54 AM
rbf_
p.1 #4 · p.1 #4 · New firmware out - Xpro1/2, lots of lenses
Yes, particularly since this update for the XP2 will add support for the new X500 flash unit and break a lot of third party support, including my nifty Nissin i40 I do believe they support downgrade as well though.
Oct 06, 2016 at 01:58 AM
Rand47
p.1 #5 · p.1 #5 · New firmware out - Xpro1/2, lots of lenses
And, make sure to update body firmware prior to lens firmware. It may be an issue that has been resolved, but doing this in reverse order (lens first) caused some bricked camera bodies the last time there was an update for both body and lenses. Better cautious than sorry.
Rand
Edited on Oct 07, 2016 at 12:44 PM · View previous versions
Oct 06, 2016 at 02:31 AM
TheEmrys
p.1 #6 · p.1 #6 · New firmware out - Xpro1/2, lots of lenses
It does say that both the Xpro1 and 2 must be updated prior to the lenses update. I just updated my lenses, apparently for no reason as I have an XT2 instead of the Xpro2. Three cheers for late night desires to "get something done."
If it is any consolation, I did three at once. Copied all the firmware files over, and was able to update the 16, 23, and 18-135 in order. I have to say that Fuji has a pretty slick, smart method of firmware updates.
I cannot wait to see what the XT2 is going to look like in 2 years.
Oct 06, 2016 at 04:58 AM
darthalal
p.1 #7 · p.1 #7 · New firmware out - Xpro1/2, lots of lenses
I was able to do the same; X-Pro2, then 14mm, 23mm, 35mm, 50-140mm, all from the same card that I copied the updates onto all at once. *thumbs up*
Oct 06, 2016 at 05:02 AM
lexvo
p.1 #8 · p.1 #8 · New firmware out - Xpro1/2, lots of lenses
Kudos to Fuji for bringing out a firmware update for the 4 year old X-Pro1!
Oct 06, 2016 at 03:30 PM
esanchez
p.1 #9 · p.1 #9 · New firmware out - Xpro1/2, lots of lenses
Yes even if it's just a small update. That is why I love Fuji and still love my X-Pro1
Oct 06, 2016 at 04:09 PM
liggy
p.1 #10 · p.1 #10 · New firmware out - Xpro1/2, lots of lenses
Yep - I'm afraid I'm going to have to wait on the X-P2 upgrade as I'll need the i40 working on the X-P2 in a couple of weeks.
You early adopters can do the heavy lifting on the debugging.
Oct 06, 2016 at 04:30 PM
SethD
p.1 #11 · p.1 #11 · New firmware out - Xpro1/2, lots of lenses
Any word yet on whether this upgrade plays nicely with the Zeiss Touit's (12 and 32)?
Oct 06, 2016 at 06:14 PM
flash
p.1 #12 · p.1 #12 · New firmware out - Xpro1/2, lots of lenses
I really like my i40's. Any news on whether we will be able to update the flash so it's not bricked on the new camera firmware?
Gordon
Oct 09, 2016 at 07:54 PM
liggy
p.1 #13 · p.1 #13 · New firmware out - Xpro1/2, lots of lenses
Gordon
Yep! There is an update from Nissin. You'll need to contact your local distributor.
Oct 09, 2016 at 08:25 PM
Berschwinger
p.1 #14 · p.1 #14 · New firmware out - Xpro1/2, lots of lenses
All this about needing to do the camera first before lenses - what about cameras that didn't receive an update? Is my X-T1 going to brick because I updated my lens?
Oct 11, 2016 at 03:07 PM
TheEmrys
p.1 #15 · p.1 #15 · New firmware out - Xpro1/2, lots of lenses
Why would it? It is only applicable to the two bodies that need updates.
Oct 11, 2016 at 04:26 PM
Berschwinger
p.1 #16 · p.1 #16 · New firmware out - Xpro1/2, lots of lenses
Just an honest question: if a working x-pro2 and 18 f/2 combo will brick by just updating the lens, why would the x-t1 be any different? Only difference is there is no new release of x-t1 firmware. I'm sure there is no issue to be had, but the logic doesn't make sense when the x-pro2's old firmware also came after the x-t1's current.
Oct 12, 2016 at 04:02 PM
TheEmrys
p.1 #17 · p.1 #17 · New firmware out - Xpro1/2, lots of lenses
Because the lens update is set to corrdct issues with the OVF. In the firmware, the lens (and body) are both aware that there is no OVF to check for. That entire sequence of code logic is bypassed.
Oct 12, 2016 at 04:12 PM
Pavel
p.1 #18 · p.1 #18 · New firmware out - Xpro1/2, lots of lenses
Support for a four year X-Pro1? Is Fuji amazing, or what?
Oct 12, 2016 at 07:18 PM
GiovanniAprea
p.1 #19 · p.1 #19 · New firmware out - Xpro1/2, lots of lenses
Which on field improvements did you notice? I am interested into the old X-Pro1 and the 14-35 and 18-55 coupled with the camera.
Thank you
Oct 13, 2016 at 02:38 PM
SethD
p.1 #20 · p.1 #20 · New firmware out - Xpro1/2, lots of lenses
To answer my own question - I upgraded and the Zeiss lenses seem to work just fine.
Oct 14, 2016 at 01:04 PM
