Archive 2016 · Radio trigger for 580EXII for ST-E3 and HSS
NCAndy
p.1 #1 · p.1 #1 · Radio trigger for 580EXII for ST-E3 and HSS
I have 2 600EX-rt and one 580EXII flashes. I read on one of these boards that there is a radio trigger I can add to the 580EXII so it will operate with the ST-E3 and the other 600EX-rt flashes. I can't find that thread now. What I want to do, is use the 580EXII in a 3 flash setup in HSS either bounced or shot through an umbrella in HSS mode using the ST-E3 as master. Does anyone know of such a radio trigger, one that will work in TTL and HSS with the 580EXII? Thanks.
Sep 21, 2016 at 10:37 AM
c102690
p.1 #2 · p.1 #2 · Radio trigger for 580EXII for ST-E3 and HSS
Think I've come across a youtube video that states you can mount a 580EXII on YNE3-RX receiver, set to same channel and 4-digit ID as the trigger to incorporate 580EXII into canon RT system.
I don't have first hand experience, so you may have to research the capability and inter-operability of YNE3-RX with Canon RT system. Also, my research on this indicates you can trigger 580EXII with this configuration in the RT system but power output will need to be set manually...this much I saw from a post in POTN board.
Sep 21, 2016 at 11:19 AM
NCAndy
p.1 #3 · p.1 #3 · Radio trigger for 580EXII for ST-E3 and HSS
Thanks. I was hoping to also keep TTL compatibility with the trigger. I'll check it out but I think there was another trigger, wish I could find that thread. I may cross post in the lighting board.
Sep 21, 2016 at 11:29 AM
c102690
p.1 #4 · p.1 #4 · Radio trigger for 580EXII for ST-E3 and HSS
See if any of these links help. Good luck!
https://www.fredmiranda.com/forum/topic/1440898/0?keyword=st-e3-rt,580ex#13644503
https://www.fredmiranda.com/forum/topic/1423234/0?keyword=st-e3-rt,580ex#13501494
Sep 21, 2016 at 11:49 AM
NCAndy
p.1 #5 · p.1 #5 · Radio trigger for 580EXII for ST-E3 and HSS
Thanks! That was the thread I searched for, I even commented in it back when it was current. I ordered the Yongnuo trigger. Worth a try.
Sep 21, 2016 at 12:51 PM
mb126
p.1 #6 · p.1 #6 · Radio trigger for 580EXII for ST-E3 and HSS
The Yongnuo works very well in my experience.
Sep 21, 2016 at 01:20 PM
c102690
p.1 #7 · p.1 #7 · Radio trigger for 580EXII for ST-E3 and HSS
Great!
Let us know your experience. I'm transitioning from YN-622C-TX to YN-E3-RT system but don't want do away with my existing 580EX II and YN-568EX II speedlights. I purchased a YN600 EX recently and looking to get anotherYN600 EX and the YN-E3-RT trigger.
Thanks
Sep 21, 2016 at 02:41 PM
NCAndy
p.1 #8 · p.1 #8 · Radio trigger for 580EXII for ST-E3 and HSS
c102690 wrote:
Great!
Thanks
It's a bit of a price toss up with the trigger costing $41 and a YN600EX $114. The Canon 580EXII is probably more robust than the Yongnuo flash and since I already have it... I'll take a chance on the trigger for my application.
Sep 21, 2016 at 02:44 PM
diverhank
p.1 #9 · p.1 #9 · Radio trigger for 580EXII for ST-E3 and HSS
The YN-E3-RX adaptor (costs $40) when mounted with the 580EXII will essentially turn it into a radio-controlled capable (e.g. 600EX-RT) with full ETTL functionality and works perfectly with the Canon ST-E3-RT controller. I'm using this combo.
Sep 21, 2016 at 04:06 PM
NCAndy
p.1 #10 · p.1 #10 · Radio trigger for 580EXII for ST-E3 and HSS
Thanks, I ordered the YN-E3-RX so good to know it will do what I want with the 580EXII.
Sep 21, 2016 at 08:52 PM
