       2       3              8       9       end
In Stock: Laowa 15mm f/2 FE for $850
Admin
p.1 #1 · p.1 #1 · In Stock: Laowa 15mm f/2 FE for $850
Laowa 15mm f/2 FE Zero-D unveiled!
The new Laowa 15mm f/2 FE Zero-D lens is now available for preorder at B&H Photo with availability in 2 weeks!
B&H Photo | Adorama ($849)
Help support FM by using our links for your purchase! - Thank you!
Make sure to check the Laowa 15mm f/2 FE: Rolling Review
_________________
Main features:
  1. E-Mount Lens/Full-Frame Format
  2. Aperture Range: f/2 to f/22
  3. Three Extra-Low Dispersion Elements
  4. Two Aspherical Elements
  5. Rectilinear Design, Low Distortion
  6. Frog Eye Dust & Water-Repellent Coating
  7. Manual Focus Design
  8. Manual Aperture Ring Can Be De-Clicked
  9. 9-Blade Diaphragm
  10. Weight: 500g
  11. Filter thread: 72mm
  12. Elements/Groups: 12/9
  13. Angle of view: 110 degres
  14. Minimum Focus Distance: 15cm!!
Press-release:
Anhui China, Sept 14, 2016 – Venus Optics, the camera lenses manufacturer who had previously launched a number of quality lenses with ‘World’s First’ specifications, is proud to unveil two premium lenses with extreme specifications and impressive performance, the Laowa 15mm f/2 FE Zero-D & the Laowa 7.5mm f/2 MFT.
The new Laowa 15mm f/2 FE is currently the World’s Fastest 15mm rectilinear lens for Full Frame cameras. It features a close-to-zero optical distortion, allowing photographers to take landscape or architecture shots with straight lines retained.
Dedicated to fulfill the need of photographers, Venus Optics have managed to add a 72mm filter thread onto the 15mm f/2 lens. Photographers can easily install standard screw-in filters without paying for an expensive yet bulky filter holder system.
Designed specially for the Sony Full Frame Mirrorless cameras, Venus Optics has successfully controlled the size and weight of the lens to the minimal. Weighing less than 1.1 pounds (500g) and 82mm in length, the portability and compactness of the Sony E- mount Mirrorless cameras can be maintained when used with the Laowa 15mm f/2 FE Lens.
Featuring the fastest f/2 aperture ever built with a 15mm lens, the new Full Frame E- mount lens is engineered for professionals to shoot impressive landscape, architecture and primary astro photos with great details. This is an every-day and must-buy lens that every Sony Full Frame Mirrorless camera user should have one in his bag.
Availability
The Laowa 15mm f/2 FE Zero-D and the Laowa 7.5mm f/2 MFT will be available to the market in early 2017. Engineering prototype will be available to test in Venus Optics’ Photokina debut. Venus Optics’ booth is in Hall 2.1, Booth A-045.
Sep 13, 2016 at 09:29 PM
Tmuussoni
p.1 #2 · p.1 #2 · In Stock: Laowa 15mm f/2 FE for $850
500 grams, 72 mm filter thread, 15mm f/2. This is simply remarkable! And the MTF look pretty good.
Sep 13, 2016 at 09:35 PM
trogdon
p.1 #3 · p.1 #3 · In Stock: Laowa 15mm f/2 FE for $850
Wow the ~14mm space is really heating up. It went from adapting the 15mm voigtlander, to a native 15mm voigt, an AF 14mm 2.8 from Samyang, a very fancy 14mm f2.4 from Samyang, to this quite tiny and remarkable 15mm f2 from Laowa. They are quite the up and coming optics company, color me impressed
Sep 13, 2016 at 09:39 PM
GMPhotography
p.1 #4 · p.1 #4 · In Stock: Laowa 15mm f/2 FE for $850
This one out of all the latest looks interesting to me. Small and takes filters . Speed is nice too. Have to see how this tests out. I do not want a big 14/15mm having the VC 15 but I would not mind having something faster
Sep 13, 2016 at 09:42 PM
Gary Clennan
p.1 #5 · p.1 #5 · In Stock: Laowa 15mm f/2 FE for $850
A 14mm or 15mm fast lens with good coma control is what I am after. It can be absolutely massive - wouldn't bother me a bit. Looks quite interesting....
Sep 13, 2016 at 09:45 PM
Admin
p.1 #6 · p.1 #6 · In Stock: Laowa 15mm f/2 FE for $850
Don't forget about the Batis or Loxia 15mm next.
Sep 13, 2016 at 09:47 PM
DavidBM
p.1 #7 · p.1 #7 · In Stock: Laowa 15mm f/2 FE for $850
Wow! MTF at 2.8 is great, not as amazing as the Sammy 'premium' but close.and f2 is similar. And it's almost half the weight! The mirrorless advantage for wides that we saw finally in L21 coming to our aid again.
I'd prefer an f2.8 and take an even bigger size/weight saving. But I think that's going to come from Zeiss if it comes from anyone, so I won't be making a cost saving!
Sep 13, 2016 at 10:21 PM
pizdets17
p.1 #8 · p.1 #8 · In Stock: Laowa 15mm f/2 FE for $850
looking forward to those too, but doubt they will be faster the 2.8, seems to be Zeiss standard for those focal lengths..
Sep 13, 2016 at 10:24 PM
mcbroomf
p.1 #9 · p.1 #9 · In Stock: Laowa 15mm f/2 FE for $850
My head is spinning in the fast 14/15 market; Sammy MF, Sammy AF, Sammy Premium, Laowa, Zeiss Distagon, Irix, and maybe Batis or Loxia ...
I had ordered the new AF Sammy to see if it would be a substantial improvement for astro over the older MF, but I cancelled it and I'll let the wars play out then get one of the survivors
Sep 14, 2016 at 09:59 AM
rji2goleez
p.1 #10 · p.1 #10 · In Stock: Laowa 15mm f/2 FE for $850
This looks like a very interesting Astro lens. I prefer the MF lens over the new Samy with AF since my use would almost entirely be astro. Even if this lens suffers a bit at f/2, shooting at f/2.8 should be better and yield great results for Astro.
Sep 14, 2016 at 10:10 AM
WestTexas Sky
p.1 #11 · p.1 #11 · In Stock: Laowa 15mm f/2 FE for $850
This looks very interesting as an Astro lens where the extra stop would be very welcome. This is what the Samyang 14mm FE lens should have been instead of auto focus, which seems wasted on such a wide.
Hoping for low coma.
Sep 14, 2016 at 12:19 PM
akclimber
p.1 #12 · p.1 #12 · In Stock: Laowa 15mm f/2 FE for $850
Me too! Could be a very nice astro lens.
Sep 14, 2016 at 04:05 PM
Beni
p.1 #13 · p.1 #13 · In Stock: Laowa 15mm f/2 FE for $850
The entrance pupil mark, though rather overdone, is very welcome for pano photographers. As anyone who has spent hours testing a wide angle to find the exact point can tell you Nice addition.
Sep 15, 2016 at 05:12 AM
Chris_88
p.1 #14 · p.1 #14 · In Stock: Laowa 15mm f/2 FE for $850
Bob, I'd be more interested in comparing this Laowa lens to the new "premium" Samyang 14 2.4. The latter with its 18 elements is quite a bit larger and heavier and probably more expensive too. Then again, I usually carry an astro lens only when I know that I'm going to use it, so I wouldn't mind the extra weight, if the Samyang was considerably better than the Laowa or the current MF 14 2.8.
Sep 15, 2016 at 06:05 AM
pdmphoto
p.1 #15 · p.1 #15 · In Stock: Laowa 15mm f/2 FE for $850
And I'm guessing a Batis or Loxia will be at least 2-3x the cost of the Laowa.
Sep 15, 2016 at 06:31 AM
pizdets17
p.1 #16 · p.1 #16 · In Stock: Laowa 15mm f/2 FE for $850
but they will work and have a good warranty
Sep 15, 2016 at 07:13 AM
sorpa
p.1 #17 · p.1 #17 · In Stock: Laowa 15mm f/2 FE for $850
Looking forward to seeing some reviews/comparison between Lowa, Samyang and Irix.
Sep 15, 2016 at 12:17 PM
nampramos
p.1 #18 · p.1 #18 · In Stock: Laowa 15mm f/2 FE for $850
When do you guys think we will get a more concrete release date for the15/2 and price?
Oct 25, 2016 at 05:42 AM
Ipanematom
p.1 #19 · p.1 #19 · In Stock: Laowa 15mm f/2 FE for $850
Laowa is coming out with a12mm f2.8 rectilinear lens in Dec 2016. Looking forward to it!
Nov 22, 2016 at 11:18 PM
Neurad1
p.1 #20 · p.1 #20 · In Stock: Laowa 15mm f/2 FE for $850
Any news on the 15 F2? It's early 2017 and I'm still waiting!!
Mar 03, 2017 at 05:08 PM
       2       3              8       9       end
       2       3              8       9       end
