Archive 2016 · Fuji X-T2 freezing.
richard371
p.1 #1 · p.1 #1 · Fuji X-T2 freezing.
So far I've had this happen twice. Not when shooting but once I just picked it up and the viewfinder was frozen. Nothing worked until I pulled out the battery. The other time was when I put a battery in it. I think I left the camera on and it froze. Hopefully this is something that can be fixed in FW.
Sep 13, 2016 at 05:02 PM
sold5
p.1 #2 · p.1 #2 · Fuji X-T2 freezing.
when using a non 's' fuji battery ie the new one that comes with the xt2 and shooting in busy bursts the battery can heat up, lose power output and the camera freezes up. The YouTube 'angry photographer' has a long winded 19 minute video explaining this but no real extra detail. Are you using a new battery with 's' at the end of the name? It's got 4 contacts instead of 3 and handles heat better apparently
Sep 13, 2016 at 05:15 PM
richard371
p.1 #3 · p.1 #3 · Fuji X-T2 freezing.
yes and it wasn't hot at all nor was the camera.
Sep 13, 2016 at 05:26 PM
JustShootMe
p.1 #4 · p.1 #4 · Fuji X-T2 freezing.
Mine froze once as well , I don't remember what I was doing but I also had to remove the battery for it to reset. That was the first day, hasn't happened since. It was frozen with the lcd still on.
Sep 13, 2016 at 05:47 PM
richard371
p.1 #5 · p.1 #5 · Fuji X-T2 freezing.
Just spoke to Fuji and the guy I spoke to was pretty knowledgable. He said he already gotten 3 calls in regards to this and Fuji engineers are aware of the issue and working on a FW fix.
Sep 13, 2016 at 06:37 PM
leighton w
p.1 #6 · p.1 #6 · Fuji X-T2 freezing.
The only time mine has froze is when it's writing data from a burst of shots. Once the yellow light went off all was fine.
Sep 13, 2016 at 07:07 PM
Pavel
p.1 #7 · p.1 #7 · Fuji X-T2 freezing.
Is the X-T2 running windows 10??
Sep 13, 2016 at 08:46 PM
charles.K
p.1 #8 · p.1 #8 · Fuji X-T2 freezing.
My XPro 2 froze a couple times in the beginning, and I did not realize you had to update the FW of the lenses. The XPro 2 had no further issues.
Now with the XT2 so far no issues. I suspect maybe it is related to the type of SD cards used.
Sep 13, 2016 at 08:50 PM
BrianBlair05
p.1 #9 · p.1 #9 · Fuji X-T2 freezing.
MY XT2 seems to only freeze in the wifi menu, when searching for a network in the pc transfer menu it has frozen 100% of the time. No matter what I do it freezes even with the sd card removed, letting the battery sit with a full charge in the camera for 24 hours did nothing (xpro2 early fix). I have contacted fuji but have yet to hear back. I assume it is FW related, fingers crossed.
Sep 13, 2016 at 11:05 PM
esanchez
p.1 #10 · p.1 #10 · Fuji X-T2 freezing.
Anyone else with this continuing problem of X-T2 freezing. Last night it was the second time my X-T2 froze. EVF stays on with the last picture I took and the flashing light writing to the card stays on blinking. The camera is no response till I remove the battery. Very annoying. Never had this problem with my X-T1.
Nov 12, 2016 at 04:04 PM
Daniel Smith
p.1 #11 · p.1 #11 · Fuji X-T2 freezing.
It is a handheld computer/scanner. What do you expect?
Nov 12, 2016 at 06:08 PM
cputeq
p.1 #12 · p.1 #12 · Fuji X-T2 freezing.
So far no freezes here at all.
Nov 13, 2016 at 03:32 PM
leighton w
p.1 #13 · p.1 #13 · Fuji X-T2 freezing.
I dare say the upcoming FW update will address this issue.
Nov 13, 2016 at 03:34 PM
pompo
p.1 #14 · p.1 #14 · Fuji X-T2 freezing.
It happened to me on both xt2 bodies. I turned eye/face detection off and that freezin has not happened since. So it must have been what causes it in my case.
Nov 13, 2016 at 05:31 PM
Ariel70
p.1 #15 · p.1 #15 · Fuji X-T2 freezing.
Same thing here, I turned on the face/eye af and it froze tonight like three times in 5 minutes.
I stopped using it then, but will try again with that feature off.
Nov 14, 2016 at 05:03 AM
Daniel Smith
p.1 #16 · p.1 #16 · Fuji X-T2 freezing.
Eye control and face detection and it freezes?
Maybe you need to get better looking people to photograph? ;-)
Nov 14, 2016 at 03:59 PM
James R
p.1 #17 · p.1 #17 · Fuji X-T2 freezing.
No loss there since that function doesn't work that well.
Nov 14, 2016 at 05:26 PM
esanchez
p.1 #18 · p.1 #18 · Fuji X-T2 freezing.
I called Fuji support yesterday and they recommend I sent in my X-T2 for them to take a look. I asked about the FW update and they said they were not aware that update would fix the freezing.
Nov 15, 2016 at 02:53 PM
mjc
p.1 #19 · p.1 #19 · Fuji X-T2 freezing.
Hmmm. If you send it back, please do let us know what Fuji says...
Nov 15, 2016 at 03:36 PM
guidoryan
p.1 #20 · p.1 #20 · Fuji X-T2 freezing.
I had a camera that did the exact same thing. I returned to seller and no more problems.
Hope you resolve.
guido
Nov 17, 2016 at 12:43 AM
