Todd Ryburn Offline Upload & Sell: Off
I've been using the 1DX2 for about a month now and one issue with a particular lens/ext combo has come up.
When I use the camera with a 70-200f2.8 IS V2 and 2.0 III extender I have a weird issue with the shutter speed adjustment. When I attempt to raise the shutter speed it will go up two notches (2/3 of a stop) then shutter speed stops adjusting even though I'm still spinning the wheel.
If I lower the shutter speed and then increase it again the problem goes away. This has happened to me twice and both time with this lens/extender combo. I've used the camera with about 5 other lenses and with both the 1.4 and 2.0 extenders (both V3). Both times the problem occurred the first time I moved the shutter, then never repeated. I turned the camera on and off both times as well.
I am attaching the extender to the lens, and then to the camera (with the camera off). I used this combo on the 1dx, and 1div with no issues. I was worried it was some sort of mechanical problem with the camera, but since it's just this lens/ext combo I'm wondering if it's some sort of software issue. I'm just over the 30 days with B&H, and the camera seems perfectly fine other than this issue. I'll probably call CPS on Monday and see what they think.
I was curious if anyone else had a similar type of issue.
Thanks,
Todd
