kv9f68 Offline Upload & Sell: Off
C,
Well if you're getting a dark band, evidently the HSS isn't kicking in.
With my set-up I have the TX in the hotshoe set to HSS (I haven't even messed with SS) and the 622 tethered to the 600 via the sync port. You might to try the same instead of having the 622 mounted on the RL trigger. I haven't tried this, but maybe it'll work since hijazist doesn't seem to have a problem with that configuration.
Also make sure that the Rovelight itself is set to HSS.
And that link that was provided has a ton of info about various setups if you can find the time to go through it. Sorry if I couldn't help more.
Kevin
