Archive 2016 · MD 35-70 macro lens - is this normal?
taemo
p.1 #1 · p.1 #1 · MD 35-70 macro lens - is this normal?
Looking to purchase a Minolta MD 35-70 macro lens, found online for a good price but not sure if it's faulty or not.
On their description it says "operationally it might be a little bit loose and wobbly if you shake it".
Is this common with this lens? worth the shot or should i just skip this.
May 22, 2016 at 10:55 PM
Desmolicious
p.1 #2 · p.1 #2 · MD 35-70 macro lens - is this normal?
Mine does not do that, I'd skip this one.
May 22, 2016 at 11:33 PM
taemo
p.1 #3 · p.1 #3 · MD 35-70 macro lens - is this normal?
thank you for the confirmation, i'll look for a better copy then.
May 23, 2016 at 12:27 AM
TheEmrys
p.1 #4 · p.1 #4 · MD 35-70 macro lens - is this normal?
Its pretty normal. You can tighten up the screws very, very easily. Probably get a good discount because of that. I have had 1 macro, and two non-macros (2nd version). One wobbled. I tightened it up, and now can't tell which one used to wobble.
May 23, 2016 at 01:49 AM
alarmchrono
p.1 #5 · p.1 #5 · MD 35-70 macro lens - is this normal?
Was it the zoom ring wobbling? I tried to tighten the screws and it did not work. Is there any disassembly guide for this lens?
Jan 03, 2017 at 07:24 PM
starlights
p.1 #6 · p.1 #6 · MD 35-70 macro lens - is this normal?
I had disassembled one a few years back. I believe the screws are under the rubber grip. I had found a website in mandarin with pictures on the web at that time.
Mar 15, 2017 at 11:56 PM
