Archive 2016 · Sd card craped out
richardma
p.1 #1 · p.1 #1 · Sd card craped out
So in the middle of my trip my sd card decides to break. I have not backup thewe photo yet. When I insert the memory card it says cannot read, reinsert card. The memory card is not detectable by both my camera and computer. What do i do?
Ive tried putting sd card into a different camera.
Ive tries taing out battery
Tried putting into laptop which does not detect.
Tried using recuva but since computer does not detect can't scan it
Any recommendations or good priced companies
May 19, 2016 at 01:37 PM
Gochugogi
p.1 #2 · p.1 #2 · Sd card craped out
Do not reformat or write new files to the hosed card. Set it aside and use a file recovery app to dig through the card and save as many images as possible. I've gone through this a couple times in the past 15 years and RescuePro saved my bacon, recovering hundreds of images. There are dozens of such apps on the market and many will let you recover a handful of files for free but you'll have to pay the piper if you want all your files! If it's only a small amount of files, EaseUS Data Recovery Wizard has one of the more generous "sample" quotas.
Afterwards, buy a new SD card and a backup SD card or two or three. Yours may not be reliable...
May 19, 2016 at 05:11 PM
richardma
p.1 #3 · p.1 #3 · Sd card craped out
Only issue is my lapop when plugged directly in does not read the card. It doesnt pop as a drive.
May 19, 2016 at 06:20 PM
Andrew J
p.1 #4 · p.1 #4 · Sd card craped out
Laptop readers are the worst. Get a new usb 3.0 SD reader, one that is firmware upgrade-able is the best bet.
May 20, 2016 at 03:00 PM
richardma
p.1 #5 · p.1 #5 · Sd card craped out
Any particular reader that you would suggest?
May 24, 2016 at 09:12 PM
Andrew J
p.1 #6 · p.1 #6 · Sd card craped out
http://alikgriffin.com/best-uhs-ii-memory-card-readers-detailed-comparison
May 24, 2016 at 09:30 PM
runamuck
[X]
p.1 #7 · p.1 #7 · Sd card craped out
If nothing can detect the card it will have to go back to the maker.
May 27, 2016 at 02:07 PM
sjms
p.1 #8 · p.1 #8 · Sd card craped out
what make and model card Is/was it?
May 27, 2016 at 02:45 PM
