chiron Offline Upload & Sell: On
p.1 #3 · p.1 #3 · any neoprene lens bags wider than 4 inches??? | |
jcolwell wrote:
I use both lenses you mentioned with hoods in Op/Tech Snoot Boots.
I've attached a photo of my 16-35/4L IS sticking out of its SnootBoot. I'm pretty sure this is a Large-Wide size, at least it's 8" long. The sizes at the Op/Tech site say it's 3.5" diameter, but mine is at least 4". I know it's not one of the Wide-Body-XL sizes, because those pouches don't have the standard belt loop and snap hook that mine has, and they're longer than mine.
Note that their site doesn't list the "Large-Wide" size, but that's what I have recorded in my inventory system. Maybe it's not made that size anymore. This size also fits the 70-200/2.8L IS II and 100-400L IS II fits OK with hoods reversed. You have to stretch it a bit to close the bag over the end cap, but it works fine....Show more →
Thank you for this suggestion. I think that the op/tech site lists these wide bags as as 4.5 inches wide, which is about a half inch wider than others I have seen. If you can get the 16-35 and the 24-70 in with shade reversed, the longer wide bags should take them with the shade mounted for use. I will give them a try.
