ben egbert Offline Upload & Sell: Off
lighthound wrote:
Thanks Ben & Kent for the conformation. That's good to hear for a change.
And yep Ben, I have tried using the various camera setting selections in LR but most times it doesn't look right to me. Just for the heck of it last night I compared the sooc jpeg files to the "standard" camera setting in LR applied to the RAW files and it was very close with these images. I could clearly see a change/difference but it was close. I think my main problem is WB color cast issues which in these images it appears the camera sensor did a good job at getting right and didn't get fooled. I had it set to Auto WB. That's when I run into trouble me thinks. Regardless, I'll be shooting an extra jpeg file to keep on hand from now on for reference. I just have to figure out a good way to keep them organized because it starts getting confusing with all the separate files.
Dave...Show more →
I am not sure Lr/PS does a good job converting colors accurately, That is why I suggested DPP. If you use the same settings in dpp as you have in your camera, it ought to be an exact match to your jpg.
The one thing is if your jpg is 8 bit sRGB and your tiff is 16bit Argb, the jpg will have less color range, some colors may be clipped. The 16 bit is actually the more accurate, but it might look different.
