jelbo Offline Upload & Sell: Off
p.1 #6 · p.1 #6 · Google Nik Collection - Fixing Scaling on 4K Monitors??? | |
Mr Mouse wrote:
I notice that the installer crated a tree "C:\Program Files\Google\Nik Collection\" in that tree each plug-in has its own tree and in the trees there are 32Bit and 64Bit exe files. If these .exe are creating the windows for the Plug-in's UI you should try creating external manifest file for all the plug-in *.exe files.
I did start one of the 64bit exe and it did create the Plug-in UI window.....
That's exactly how far I got. I can fix the .exe's and run them with fixed scaling, but when you run any Nik plugin from Photoshop, it's still tiny. Photoshop uses the .8bf file I guess, but making a <plugin>.8bf.manifest doesn't help. Doing the same for photoshop.exe doesn't help either.
/edit: I managed to sort of fix it. Downside is that images are displayed in half resolution
Adjust a regkey and create a photoshop.exe.manifest, as explained at http://www.danantonielli.com/adobe-app-scaling-on-high-dpi-displays-fix/.
Then, in Photoshop, go to Edit > Preferences > Interface and set UI scaling to 100%. This worked fine on my Surface Pro 4 with it's scaling set to 200%, the Nik plugin are now scaled big.
