EB-1 Offline Upload & Sell: Off
To be clear I meant batteries nearing end of life.
Canon LP-E4N battery pack:
•Included with EOS-1D X; can also be used in EOS-1D Mark III, Mark IV, and EOS-1Ds Mark III
•Can be charged in LC-E4N charger without qualifications
•Can be charged in older LC-E4 charger, but be aware of the following:
If an LP-E4N battery pack that has been charged and discharged many times is charged- up in the LC-E4 charger, all three of its charge indicator LEDs may blink repeatedly, which indicates a battery malfunction. If this occurs, press the Calibrate/Performance button on the charger, which changes the three LEDs to temporarily indicate a battery’s recharge performance level — in other words, its ability to take and hold a charge. If one or more LEDs display without blinking as the button is pressed, the battery is still OK.
If an LP-E4N with significant charge/discharge cycles during its life is charged using the previous LC-E4 charger, it’s possible that it may not be fully and completely recharged.The LC-E4N charger has been modified slightly to avoid this issue.
Source
