NCAndy Offline Upload & Sell: Off
Shutterbug2006 wrote:
You say you checked the settings in the camera, but you didn't say what settings you checked.
Can you confirm what settings you checked?
The camera is in one shot AF, single center point, one shot drive. The exposure is set to 100 ISO, 160s, f11. I set the flash function in the camera menu to enable AF assist beam (cf8 enabled) and verified that it was the same on the flash itself. The flashes all work properly on my other camera bodies. I'm not sure what I can do differently on the 5D3 to get the flash assist beam to work. Maybe I should try a different lens, the 16-35 is on there now. Just swapped lenses and took the camera into a dark room. No change, the assist beam doesn't come on. Guess I'll call Canon.
