rongwam Offline Upload & Sell: Off
ben egbert wrote:
Two things jump out at me, one is a sharpening halo, best seen where the right side rock juts into the sky. The second is a broader halo around the left trees, probably a blend or shadow highlight sort of thing.
This is what I consider a muted image with the blurred water and cloud style. As such it seems well done other than the nits I pointed out. The sharpening halos could weel be from web prep, the broad halo is probably there in the full size.
Thanks Ben for your comments. You are right about the broad halo. It is there in my high resolution file, and definitely from the blending that I did. The sharp halo on the right rock is not there in my high res file, it is probably due to web compression and small file size.
