WalterF Offline Upload & Sell: Off
beavens wrote:
I prefer the color version as well - it's nice to see all the browns and tans that one would expect in such a shop.
Not sure if you want to keep the noise in there, but if not then a little NR is in order.
Maybe look at tightening the crop from the bottom and right a bit.
I prefer the blown window to one with a view to a vehicle - that would spoil it. The plane highlights aren't desirable, but don't ruin the shot either.
Cheers!
Jeff
Jeff I used your suggestion of cropping a little off the bottom and right side, plus a touch of noise reduction.
Glad to hear that you think the highlights don't ruin the image.
lighthound wrote:
What has happened to the Universe?
I like the B&W on this one. I think the blown window holds up better in B&W for some reason.
Another nice one Walt!
"Cold hearted orb that rules the night, Removes the colours from our sight, Red is gray and yellow white, But we decide which is right. And which is an illusion?"
-Moody Blues-
Dave
Thank you Dave, I took a little color out per Kent's suggestion you may like it better.
RustyBug wrote:
Spit the diff ...
It has a different feel to it, softer. Then again you used a little blur to help direct the eye. I like it and with the other suggestions this is the result.
Walt
